GE C21-G2 Range Info
kb0nes
Dec 11, 2009
2,346
Burnsville, MN
A user on a Vintage Appliance FB forum is trying to date an older GE range. Here is a photo of the range and the model/serial tag.
Anyone have any information? Looking mostly for a date of manufacture and another other wisdom. Sounds like it was more or less unused for most of it's life. It looks pretty minty.
Phil,
My guess is sometime right after the end of WWII.  Here are a few ads I found from the era.  The ads indicate that range production stopped during the war (like most manufacturing sectors) and the add from 1944 shows a range purchased before the war - does not look like this one.  The later ad is from 1948 and neither does it match exactly, but looks more like this one.  I did find ads from about 1937, but they did not reference Bridgeport, Conn as the corporate address.  Both of these ads do.
Maybe this helps some.  Others might be able to offer more information as well.
lawrence
GE Airliner Range
On the attached link there are details of the 1948 Airliner range, which is the model featured in the second on Lawrence's post above. There is no doubt the range is similar although maybe not so fully featured as the Airliner seems to have at least some press buttons and two power outlets. Of course the clock is in a different position. I would suggest that the knobs are probably replacements - nice range though
Al
As you can see in the pic above the serial number on the range doesn't have the two letter code to indicate month and year of manufacture. The GE serial number info I have using them begins with 1944. So maybe that indicates this is before then? At the same time I have a 40" GE single oven range that I believe is from the late 40s-early 50s and the serial number doesn't have the two letters either which by that time it should. So go figure. [this post was last edited: 7/18/2017-17:32]
