GE Combo Rebuilding
combo52
Apr 4, 2008
17,149
50 Year Repair Tech Beltsville,Md
I started with a 1966 Avocado under counter model like I have had in my kitchen for the past 30+ years and a white 67 free standing model and one of the last a harvest gold 72 under counter model.
The goal is to have the white FS model for the museum and the 72 UC model will go to Sarah Purdue for her new mid-century kitchen she is planning and building.
I should have taken pictures before disassembly but here are some pictures of them dissembled, I promise some pictures of them assembled and working.
I’m glad you found some time to work on these. I’ve never seen a combo in person. Looks kind of like a GE top loader turned on it’s side.
GE Combos
The GE combos were one of the simplest and most rugged US combos built durning the 20 year rain of US combos, 1952-1972.
GE was the only US manufacture that sold most of their combos to builders for rental housing as well as making them part of their famous GE metal cabinet kitchens along with their other cool built in appliances.
The only parts of GEs regular FF washers that found they way into the combos was the same water pump that the very basic non FF washers used and the pump drive and of corse a high quality 1/3 HP GE motor, to wash&dry a full load in a GE combo this motor often had to run around 2 hours and they ran fairly cool and I never saw one fail. I also never saw one of the GE Calrod heating elements fail on one of these machines.
There were 12 almost totally different combos built in the US over this period of time, almost without exception all washed really well and did a superior job of removing lint and sand from clothing. The only one that tangled even slightly was the Easys with their slightly slanted tubs.
All dried really well and none ever went out of balance and required any additional attention from the user once started till the clothing came out clean and dry.
The only major shortcoming of many was poor water extraction and therefor higher energy consumption and water use for the water condensing electric models with condenser drying.
Overall they are very different and interesting laundry appliances as they all did the same thing but they all had to work around each others patents to do so.
John
Thanks for sharing these photos! I feel like I’m in a rebuild frenzy! The interior looks remarkably good from what I can see. Not sure if rust was a major concern for these machines typically. I wouldn’t even know where to begin on one of these but I’ve always admired them as well as the Kenmore combos. This will be a beautifully rebuilt machine when you’re all done!
VERY COOL!
I love the color of that avocado green. And of course THE WINDOWED DOOR!
I can't wait to see the pictures & video of them put back together, up and running! You know so much about all the different machines, it's interesting to read what you've learned about the different machines!
Can't wait to see your progress on these GE combos!
:o)
Ge Combos
It's nice to see you are starting to get some of Combos restored and sharing your progress with us all. It looks like it has vary little lint packing and rust. Keep up the good work John!
More work on the GE combo for Sarah
Did some more cleaning up last night and sealed a few little rusty spots in the bottom of the outer tub with 3M marine sealant the stuff is wonderful.
Install the last new door boot we had, fits great ready for major reassembly maybe this evening and then testing.
We've used that stuff on many of our our boats...
works well, 3M 5200 is the stuff you want!
Always wanted a GE combo, it makes so much sense to combine 2 big rotating drum machines into one, even if it increases complexity of repairs. I wish a US maker still made them, and would even seek out a vintage model were it not for the parts and knowledge situation.
My Grandparents bought a new track home in 1956 that had a GE combo in the kitchen right next to the GE DW, both in Turquoise. They also had a GE built in cooktop and oven. All of the homes in this development had the same set up. Some even had the much coveted wall fridges.
Apparently, the new owners of these homes didn’t like these combo machines at all, probably because they took so long to complete a load and also didn’t spin the loads well enough. GE came in and removed the “guts from all of these machines and left the front panels and controls in place, so there wouldn’t be a blank space. They in turn gave each of these home owners a new GE FF washer and dryer set as replacements. My grandparents used this replacement set until 1965 when they downsized into a New Moon mobile home with a pop out.
Every time I went to visit their home I always had to take a look at this “phantom” combo washing machine. I so wished that I’d gotten a chance to see it in action, but it was replaced before I ever got a chance.
Eddie
GE Under-counter Combo
Is up and working after a few problems, the old Water-pump leaked at the seal and main seal so we took a regular GE FF pump and removed the FF pump and used the cover off the original pump.
The timer also had a bad motor contact, I found a MTS rebuilt timer new in box and installed, however it was not indexed properly between the main cam switches and sub-interval cam switch so we had to use the escapement from the old timer and Jason and I got it to work.
Will put the pump back in later today and do more pictures and maybe Jason will even do a video or two of one of the best cleaning FL washers you have ever seen. This combo has 6. baffles and fills with over 5" of real hot or warm water [ there is no cold wash option ].
Hi Eugene, the original inlet and drain hoses were rubber with steel coils around the outside to keep them from kinking when the machine was installed in tight places.
On the green combo I installed a modern corrugated plastic drain hose when I rebuilt it 25 years ago which worked well.
I may transfer the outer springs onto new inlet hoses for the machine going to Sarah since this is an under-counter model.
