GE Dehumidifier Model DA1
maytag63
Jan 12, 2009
314
South Berwick, Maine
Picked up this GE dehumidifier this morning in the Kennebunk area of Maine. The owner stated that it does work but sometimes a couple of the coils freeze up from time to time. Due to the weather/heat, I didn't have a chance to plug it in or take it apart to clean and see if the fan motor needs lubrication. I hope to begin in a few days when it cools down outside.
Looked up the model online but I've not been able to find any information on it so far.
Inside
Today I plugged it in and it's low on R12. Only two coils got cold and they freeze up.
I did take apart the outer frame. Somewhat dirty. Overall pretty clean inside. Will have it cleaned up tomorrow. Too hot outside for me today.
Debating if I should recharge it. I do have an unopened can of R12 that I've had for decades. Would like some opinions on recharging it.
Low Charge ?
It could be a low charge or restricted, if a low charge it has a leak in the system although something this old if leaking it might be a very small leak and it might work for a few years with more refrigerant.
The way to find out if it is a low charge or restricted is to add 2 oz of refrigerant and if the frost pattern improves add a little more, if it improves try adding 3/4 of the listed charge amount.
John L.
