Serial # would indicate 12/1975.
This classic, "harvest gold" slide-in double oven and stove by GE works well, up and down. The upper oven door swings to the side, which is much more convenient than new ovens.
Everything works, however...
1) The oven is well used and you may want to scrub it; It's not dirty, just used
2) The indicator light does not go on when the stove burners are turned on
3) The clock no longer runs (as if you really depend on an analog clock on an old fridge these days) so you not use it for a "timed" bake
4) The stove needs one liner, which costs about $8 at Home Depot
Make any reasonable offer and it's yours. You'll need to disconnect and move the oven
