moonshiner180
Active member
I've been using my filter flo alot since it's repair and it does an awesome job of washing/rinsing, I'm just still getting used to all of it's noises I suppose. It's nothing too loud or overbearing, but does raise the question - is this normal?
I have noticed that on "gentle" speed there is a moderate amount of chattering, which I'm assuming is coming from the clutch. It seems to switch just fine from high to low speeds, agitates, rinses, spins just fine. Just during agitation there is a chattering noise. On high speed the chattering is completely gone from what I can tell. The only other observation is that it takes a little bit to get up to speed during spin, but it spins out very well and no problems with waterlogged loads or anything.
Should I just ignore it / get used to it? Or is there a repair I should look into, like say... Should I start planning on replacing a clutch?
