GE Filter-Flo Question
bobbyderegis
Dec 30, 2005
1,606
Boston
Hi All:
Any tips on the install of a new outer tub top gasket? Is it cemented to the outer tub? I know it press seals against the top cover. This procedure is not covered in the GE manual. If I put this baby into spin with a full load there will be a flash flood.
Bobby in Boston
Yikes, Mickeyd!
OK, next stupid question. I got the new gasket on, but when I close the top the back pops off the rear clips. Do I need to sit on the damn thing, or should I put some heat on the gasket (warm hair dryer) to soften it? I also notice the original gasket has some material that looks like white grease on the gasket where the lid switch arm crosses it. What is this stuff, and where do I get it?
Bobby in Boston
Here is a pic of where the stuff was. It must have acted as a sealer and lubricant so the arm would be able to turn and still stay water tight.
Bobby in Boston
Thats just white lithium grease.....hardware or auto parts store should carry it, not a sealant, vaseline should work just as well, just lubricates the shaft.....
also the new seal is really plumped up, thats what causing you to have a hard time getting the top on, and sometimes I had to get on top with all my 98 lbs...lol...and push on all four points till they snapped, but thats what you want a TIGHT seal....
