Stuck GE Clutch Driver On GE Washer Motor
Hi Paul, these can get stuck a little, but you must soak the motor shaft with some type of penetrating oil if you want to get these loose in most cases, because this part is not lubricated in normal use it can get very stuck.
You may also have to use a slide hammer type puller if the PO does not work.
