Combination Washer Dryers
"Have moved on considerably from the 50`s, when a massive sized drum capable of drying 10lbs of clothing (so able to wash 20lbs ? ) in an uber sized cabinet with drying by means of large gas burnrs or 2 / 3 large calrod burners
because the spin extraction is so slow and energy costs today would make it a no go...and the nuclear family back then was just that a large family of 6 in a typical household...
So..fastforward to the 2020`s
Max extract spinning machines give us the best water extraction, as good as spin dryers , the nuclear family is usually at best 2 people often 1 person in a home and no space for a separate washer and dryer. Clothing tends to be new lightweight modern fabrics that dont hold water etc, so for many people these new smaller washer dryers are perfect (not for everbody) and they are a very different way of operation to many laundry principles of old..
I now live in a small apartment in a very old building which has space for a washer dryer. Having used separate`s most of my life the thought of using a WD was daunting, But, I`m living on my own, so generate much less laundry than a 6 bed home, and find it great to use.I dont store up laundry over a month to wait for full max loads I use it a few times a week for 1 x hot whites wash, 1 x hot 60d light wash for towels bedding etc, 1 x hot 60d / 40 d wash for darks, I dont use the autodry but sort clothing after washing for tumble drying when required..
This machine is a Servis made by Vestel, I was given 1 to test for the UK market when they first launched here in 2013.
Spec: 9kg (18lbs) washload / 6kg (12lbs) dry, 62 ltr drum (2.4) 1400spin speed, temps from cold up to 90d ,
So a weeks worth of darks wash for me consisting of underware , socks t-shirts and cargo type pants would be a half to 3/4 full drum, washed in 1.38 mins, cottons vigerous wash , 4 rinses, intermediate spins and final 1400rpm max extract spin over 12 mins
really does leave stuff dry.I usually remove trousers and dry everything else, all dry in an hour ..
Hot whites wash for 14 cotton t shirts , 1.38 wash time @ 60d, rinses fast spin, then 30 mins times dry on high heat leaves them with just enough moisture for me to hang perfect or stretch over back of chair.
Another 30 mins (lowest manual timing) on low is too dry, I can use the autodry but it takes so long I prefer not to , the dryer is a condenser with little if any moisture escapage, it uses a calrod heater (240v 1.8kw, 10 amps) with fan attached in a metal housing on top of the drum,
hot air is blown in through a vent from the top front of the drum. This then is passed through the tumbling clothes its the back outer drum with cold condenser plate and steam is turned to water and pumped down the drain.
[this post was last edited: 6/5/2020-06:23]
