To Tim Regarding Hose
Tim-I guess I have never heard of anybody washing out hoses. I never have done that. I'm afraid that if there is any trace of moisture on the electrical contacts you might get a shock, or it might short out the hose. I would make sure that hose is good and dry, before trying to use it. If the hose is a Vinyl hose I don't see any problem, but it definitely wouldn't work on a cloth hose. Anyway--Once the hose is good and dry, and you have used it and it hasn't given you any trouble, I wouldn't worry about it. I wouldn't recommend washing hoses out. There is a relatively new product out on the market, it's called "Tornado Power" and it's made for cleaning out hoses on Central Vacuums. From what I've read about it, it's a chemically treated cloth, that you simply suck up into the vacuum and it will clean the hose. It would be a good idea, if using this product, to change your bag, as if there should be any moisture with the product, a wet paper bag would not be good. You might check with your local vacuum dealer and see if he has heard of the "Tornado Power", and see if he thinks it would be all-right to use it to clean your hose. Anyway, Tim--I'm glad I can be of help.
Nathan
