Had to buy a 1969 40" GE P7 oven off facebook for my mother, her old one literally burned up - believe she left a burner on.
Have gotten most of it to work (thanks to this specific website, and all you posters on it), but now the right side oven is on the fritz. Used to work just fine.
When I set the knob to bake or broil, (we don't use clean, or time bake) the right oven will not heat up no matter what temp we set it to.
The light above the temperature knob, which I believe tells you if the oven is heating up, does not turn on. This is the same light which turns "off" once the oven is preheated, I believe.
Well to be honest, sometimes it does work, but not for long. I did not have too much time at their house to mess with it, I believe the sensor is not working but wanted to see if anyone had advice. I've purchased the range manual / parts list from this website but cannot find great information on them, in regards to this specific problem, to be honest.
Model number is J487001
Any help is greatly appreciated
Thank you
Thank you
