GE washers with mechanical two speed clutch
Has Glenn mentioned and reply three GE thought they were engineering a great idea but everybody else was able to make top loading washers work with a nice simple two speed motor, there was absolutely no advantage to the agitation starting out slowly that was just a flaw in the design of the clutch that it couldn’t start agitating at high-speed immediately.
It would’ve been much better to use A two speed motor even machines like Frigidaires one to 18 actually would pump out on the low speed of the motor to reduce the amount of lint and scum being deposited in the clothing as a struggle to pump out the water getting up to spin speed.
A properly designed water pump would’ve allowed plenty of water flow for the lint filter when the machine was on low speed agitation, and it would’ve been much simpler and more reliable.
The three biggest flaws of GE filter flow washers was the awful two speed clutch, the fact that they filled the entire outer tub water, wasting a ton of water and detergent, and the lousy suspension system that didn’t contain vibration very well.
For these reasons, GE filter flows were really never a top-notch washing machine. John.
