General Electric Stereo Console Questions
cg223710
Oct 10, 2019
9
Ohio
I recently acquired a General Electric Stereo Console, and I'm unsure of year or model number for it. I saw that there was a fan of these in past threads and was hoping someone could help me out.
It turns on, the radio works but the speakers are about mute. The turntable sounds like its going to spin but barely moves and then stops. I haven't had the time to take the back off of it but any help I can get, I would appreciate!
My grandparents had one that was almost identical in their house and unfortunately it got lost in the transition of their home after they passed. I was able to find this one on Marketplace for $30. I don't quite care about the money it will take to fix it up as I currently have 2 generations of vinyls to play in it.
nice tube unit
This was one of General Electric's last tube units. I saw this of Facebook and was drooling over it. Glad someone from this site got it.
Often bad output capacitors are to blame for weak to no sound. If you can do some basic soldering, they are no problem to replace.
GE was still using VM changers at this time, shortly after they purchased Glasser-Steers changer company, and then began using their own.
Of course, the best thing is to disassemble the changer and clean and lubricate it. However, that may not be necessary just to get it up and running running.
I would recommend a "precision oiler." Radio shack used to carry them. Parts Express online supplier did as well, and you can also find them on Ebay. Some specifically made with synthetic oil for turntables.
They are small plastic squeeze tube with a hollow needle that will deliver oil to very specific locations, drop by drop. I use it to lubricator all my turntables.
Be careful not to get oil on the idler wheel or platter. Lubricate both bearings of the motor and the platter ball bearings.
Use a paper towel with 90 or higher percent rubbing alcohol to clean the inside of the platter where the idler rest. And use the same alcohol, on a Q-tip, to quickly clean the edges of the idler that makes content with the platter. (Wash your hands first so you do not put body oils on the parts.) Put the platter back and rotate it by hand (clockwise) until the bearing turns free, then do the same after turning the control to reject "rej." DO NOT rotate the turntable backward, this will damage a VM turntable.
Later on you may wish to do more extensive cleaning/lubricating, but hopefully this will enable you to start enjoying your beautiful machine.
Thank you so much for your input! I love the uniqueness of this one, and not just the ornate, large ones you see so often.
Any chance you know the year?!
Here are some pictures I took of it tonight! I believe the speakers are blown because there’s sound coming out but extremely dull and crackled. The turntable did start spinning, the needle picked up, but then it stopped and went right back down. Shortage maybe? Motor? I am not sure. I’ve attached all the pictures i took.
unlikely to be a speaker problem
Cara, I thoughtI might have the Sam's Photofact schematic on file for your model, but unfortunately I do not. I will try to get the exact date for you.
It is very unlikely you speakers are "blown." Your controls (called potentiometers or "pots") are probably dirty and not making good contact, this can certainly affect the sound and diminish loudness. As I also mentioned before,it is very common for the capacitors to go bad on amplifiers of of this age. Your pots are probably very dirty and/or you have faults capacitors.
Start with cleaning the pots on the volume control, balance and bass, treble. Radio Shack and even Lowe's carry electrical contact cleaner. Very safe. Just unplug your unit and use the little spray wand that came with the aerosal can and spray into the back openings of the volume pots, etc. Then rotate the controls back and forth before the cleaner can evaporate to clean the feeler and the little coils in the volume and tone controls. See if this makes any improvement in the sound in volume and or reducing the crackling. If not, next step is to get a couple of new output capacitors.
You’re a huge help! Do you happen to know of any manuals or “How-to” videos in terms of oiling the turntable like you suggested earlier?! Thanks
model year
I found the Sam's Photofact, which is a publication that breaks down the parts of the unit (tv, stereo, etc.) into what they call a schematic, and photographs all the chassis parts/components to aid in repair. Your unit appears in the 735-7 folder, which would make it a 1964 model stereo.
You have a doubly valuable unit as it is the last year that GE produced tube amps for their home audio equipment. Their 1965 consoles were all transistorized (solid-state).
I will look for any VM changer video guides for lubrication, if not I can guide you through it very easily.
Barry
'hybrid"set
Tubes under that perforated cover,but four big output transistor heatsinks can be seen :) Germanium transistors used in early transistor amps can be a bother...Will need to check those along with the capacitors mentioned upthread,solder joints,"gone high"carbon resistors,etc. Looks like it has a pretty strong amp judging by the large transistors and power transformer.
Amazing...
<span style="font-family: 'book antiqua', palatino; font-size: 14pt;">It never ceases to amaze me at the breadth of expertise we have on this site.  Great looking stereo BTW.  Looks like fun I hope you get it working correctly.</span>
tubes
Cara,
I knw many of us are talking of capacitor changes, and checking solder joints, etc. From what you say this is not your expertise nor experience.
Start with the simple and work up.
The simplest things you can do, to begin with, are to lubricate your changer and clean your controls. Neither requires any experience just a little labor and care.
Since you said you were willing to pay money, you may want to go ahead and change out your tubes. Remove the tube cover and each tube will have a number on it. You can usually find what you need to replace them on Ebay. It's as easy as changing a light bulb, they pull straight out. Do not bend them to the side as you remove or insert so you do not bend the pins. You may as well go ahead and change them out.
If you can't read the number on the tubes (a mixture of letters and numbers,for example: 12AX7) GE has a schematic on the inside of the cabinet with each tube, its location and its number.
Brendan, GE is referring to the "Porta-Fi" music distribution system which sends out a signal for remote speakers, over the homes electrical wiring system. The owner can buy the optional Porta-Fi System and plug the receiver/speaker in anywhere in the house for remote (however, monophonic) music.
There are different channels to prevent interference from multiple systems on the same lines.
So for the tubes, I looked at the schematics in the Sam's Photofact that you spoke about, and it has 7 listed, but looks like there's four V7's on the schematics. Find attached pictures. Like I said, I have ZERO experience but I'm excited to figure it out!
I also just looked up tubes, and would you suggest they be the same brand? Or would it be okay to have half GE and half RCA?
Tube brand shouldn't matter as long as it's the same type of tube (using that number/letters ID on the tube, such as 6BA6). In the radio era (and maybe when this was made), there might be suggestions on the label saying something like: "For best performance, use nothing but our tubes!" But I've noticed that most electronics of the tube era usually have a mix of brands.
I've only quickly scanned the above,so I might have missed something. But I'm not sure replacing the tubes would make much sense. Yes, they wear. But there is a good chance that they still work well enough to at least get started. Problems in something this age are more likely to be elsewhere--like capacitors as mentioned above.
Tube health can be checked by testers--although finding someone with such a tester would be difficult in this era.
tuner section
Your tube chart indicates the tubes are for the tuner section. There should be a separate section for the audio amp in the Sams folder.
Most likely your tuner tubes are good as you are receiving a signal, it is just not getting amplified properly.
As John says, (if you do have tube amp, and I am beginning to think you do not, but we'll see) there is no way to ascertain if the tubes are good or bad, without a tester. Testers are not readily available anymore to the general consumer. At that age tube can get weak. Most people just replace all tubes when they refurbish a stereo or TV.
But before we make a move on that issue we need to find out if your audio amp is solid state or not. Please scan the audio section of the Sam's folder.
Odd's are you are going to need output capacitors, it is a very common failure point among audio amps of that age. It's not a bad idea to replace them with fresh capacitors anyway, whether they are good or bad, just as its good to refresh your tubes. It would be up to you if you want to try it on your own or just pull the amp and take it to a technician to have the caps installed.
Remember there are other possibilities for your sound problems, but we have hit the most probable, and the easiest ones for a beginner to attack.
tuner section
As John says, (if you do have tube amp, and I am beginning to think you may not, but we'll see) there is no way to ascertain if the tubes are good or bad, without a tester. Testers are not readily available anymore to the general consumer. At that age tubes can get weak. Most people just replace all tubes when they refurbish a stereo or TV.
I would say the odds are about 8.5 out of 10 you have bad caps.
If money is not an issue, pull your tuner and amp and take it, with your Sam's Photofact manual, to a vintage electronics enthusiasts or find and electronics repair technician. Just tell them you want an overhaul/renewal. They will clean all your pots, the tuner, replace the output caps and check circuit board test points with an oscilloscope, for proper waveform, and replace worn components as necessary. It may cost you a bit more but then your General Electric stereo should be ready to give you another 55 years of service!
For your changer, odds are you can lubricate and clean it enough, yourself, to get it going and play records at proper speed. VM (Voice of Music) changers of that age commonly will slow and struggle a little, sometimes even stalling, on the changing cycle. Don't panic. Nothing major wrong, just hardened grease and some accumulated dirt. Sometime in the future you may want a technician to totally disassemble the turntable and clean the gears and bearings then re-lubricate. It will run like new.
