General Electric Stereo Console Questions
Did you watch the videos I attached above? I read earlier about how the sound could be due to bad capacitors, but I just want to make sure!
Also, does that mean that someone switched out the turntable? Could that be causing me issues as well?
Thanks!
changer lube
Hi Cara,
Yes, that is a VM changer as I had mentioned,previously. The next year GE began using Glasser-Steers designed changers, as they had purchased the company.
The white retainer ring around the spindle will move up on the spindle. Unlike most changers, that model of VM does not use a metal clip ring to hold the platter down.. This white ring does not need to be un-clipped from a groove. Simple take a small slotted screwdriver and CAREFULLY put it under the edge of the retainer and push upward. Once you get it up high enough, you can continue to push it up the spindle with your fingers, it will slide and roll its way up. It is a flexible polymer ring, that VM used so be careful not to cut in in half with the screw driver.
Then carefully take the platter in your fingers and move it up the spindle. It may take a little rocking back and forth before it will slide. Use caution as there is a metal washer and beneath that a ball bearing ring. They sometimes will stick to the bottom of the gear at the base of the platter, especially if the grease has hardened.
