whirlcool
Today I had to do a bi monthly chore we do here at the house. Cleaning the panes of glass on our outside gas powered lantern. Usually it gets calcium spots on it from the rain that hits it and also dust and grit from the air. There are four glass panels that seem quite fragile to clean.
Normally I take their pieces to the bath tub and wash them in Dawn detergent then you have to dry them to see where the calcium spots are then use either vinegar or CLR to clean those off. Rinse them off and repeat until all four of them are clean. The whole process takes about 30 minutes to accomplish.
Today I said to myself there has to be something I could use to speed this process up. So I went into the bath and grabbed the bottle of SoftScrub with Bleach. I wet each panel with water first than using a piece of strong wet paper towel I applied the SoftScrub to the glass. I moved the towel up and down then left and right all over the panel on both sides. Then I rinsed and used a microfiber towel to dry them(no water marks).
I was amazed at the job this did. There were no calcium marks, no dirt whatsoever and the glass felt like it just came out of the dishwasher. Very smooth feeling. And it seemed even more transparent, just like they did when they were new (they are 13 years old) and the originals. I was amazed. When they were reinstalled in the fixture they looked like there was no glass in the fixture at all.
Next I did the light fixture in the kitchen with is an opaque square glass fixture. Same results. Usually you have to scrub to get grease and dirt off of it.
Hope others here can use this tip!
http://quart
http://quart
