fridgenut
Glad to see it works...
Sorry to hear it shocked you. I was actually the one who helped Travis move this beast. Thankfully the previous owner was quite built and made loading it up easy. He even had an ancient 78 rpm jukebox that was interesting. Unloading it wasn't too bad but I did have to squat down more than normal when taking it out of the truck on its dolly. She's a thick mama jama!
You did a fantastic job of cleaning it up. It was filthy with mold and nicotine stains. You brought the life back out of it.
Since it isn't grounded and you are standing on a concrete floor you always have the possibility of getting shocked. Not to say there isn't something wrong. Some component is leaking a little voltage to the body. Grounding it will help get rid of the shock but it will not get rid of the leaking component. Thoroughly check the wiring to see if you see any problems.
