Got in multiple machines today
maytaglover68
Apr 17, 2025
94
Philadelphia, PA
Whirlpool WTW4816FW2 washer - bad bearings and loud on the spin cycle. Roaring on the spin, manufactured on the 33rd week of 2019. Not worth fixing as it will need a transmission. This machine has good control board, water valves, suspension rods, drain pump, actuator, splutch, and tub.
Whirlpool WTW5000DW0 washer - made on 32nd week of 2014, loud spin cycle and has roaring bearings. Not worth fixing. Run a test and it was roaring on the spin cycle. I can spin the drum and hear the bearings.
I also got in this older 2010 Maytag Bravos X VMW washer model MVWX500XW0, made on 39th week of 2010, has a loud bearing and cosmetic wear, so it’s not getting fixed. This is the VMW type not the stator. This is one of the first VMWs as it’s the original 2010 model, has a bad bearing but I did get one of those.
I also got in a Whirlpool WTW5000DW1 washer that needs a new tub bushing and hub, tub has a lot of play and washplate moves freely, so I’ll need to put the red bushing and new hub on this. And I got in a Whirlpool WTW5057LW0 washer from 2022 with a bad control board.
I got in this Amana NTW4650YQ0 washer that needs suspension rods and a Whirlpool WTW4800BQ0 that also has bad suspension rods.
The Kenmore 110.20222013 and Whirlpool WTW4800XQ4 also have bad shocks. I also got in this GE GTW460ASJ6WW that is not draining - probably has a bad drain pump. The kenmore 110.20022013 has a broken tub because the suspension rods got so bad, so I’ll have to put a used drum on this one.
The Maytag MVW7232HW0 washer I got in from 2020 (45th week) also has a bad board.
I had a GE with bad suspension rods, a new set was more than half what the machine cost new. We lifted the springs and bottom washers about an inch and a quarter, and put a bead of weld around the rods to move the washers up from their original spots. Used it for a year or so and sold it to a buddy. Not the most orthodox method, and certainly not something you'd do for a customer, but...
