Green as Neutral and White as Active
Chetlaham
Mar 11, 2013
4,252
United States
Why was green used as a neutral (or even hot) and white as a live conductor in appliances manufactured between the 1950 and 1960s? And what color was used when grounding was required? What was the reasoning behind this?
I think this thread should go in the super forum index since it’s a thread for miscellaneous appliances, questions about auto repair, repairs around the home, wiring etc.
I'm thinking of major appliances like the BD Whirlpool in this thread:
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?17000
The wires hot wires for the motor, tub lamp, solenoids, ect are mostly white, while the common neutral for the suds valve, water valves and wig-wags is green.
While in the NEC does not apply internally to home appliances, I am wondering what color code standard manufacturers followed in the 50s and 60s and why it wasn't harmonized like it is today.
“Norge washing machines all the wiring was white”
Sounds like that would be a pain to figure out what goes where if you had to replace something or dismantle it for a servicing etc. Probably would use electrical tape in different colors (if that was a such thing back then) as some sort of reference on how it all goes back together.
I think one of the reasons why they went to all color coded wires is it’s much, much easier to identify what goes where and how to put it back together.
