guess what I bought
Great pic, thanks for showing us what you see!
If the spot really bugs you, buff it a little with some fine Scotchbrite. That will remove the rust spot right away. A bit of CLR or Oxalic acid would probably wipe it away too.
When stainless steel is formed, rolled, cut, machined etc., its always possible that a small fragment of steel from the machine tool can be pressed or embedded into the surface. This material will rust and cause a visible stain like this. Passivation is a post finishing process where they soak the stainless piece in a warm acid and it dissolves away any ferric (steel) molecules on the surface to prevent this from happening. It helps to restore a clean, passive corrosion resistant layer on the surface. Its usually only done for critical pieces for medical or food processing industries. It would be WAY overkill for a laundry tub!
I'd just continue to use the machine, the clothing will polish the inside of the tub soon enough. I would NOT call for service, this is a non-issue unless is doesn't go away after a while.
Rust Spot
Is this the only spot in the tub? Or only the one you photographed.
Can you feel it when you rub your finger across it?
I would probably try a little Barkeeper's Friend to see if it would come off easily. I bet it would.
In any case, I recommend retaining the photo in case you need to contact Alliance about it in the future.
Malcolm
Hi Beth, no I didnt notice it till last night, even during the initial wipe down. This could only happen to me lol...I will try the barkeepers friend as suggested here. Is it possible the rust could corrode so far thru there would be a hole? I love this washer and its not going anywhere lol. As stated it has a lifetime warranty on the tub so there's no rush to call anyone...I have a load soaking but when its done I want to post another pic if I can get to it with a camera...close to the bottom of the tub, about 2 or so inches up from the bottom theres a ring around the entire tub, it looks like deep groved lines were ingraved into it, it feels slightly rough, so I took a nylon stocking and gently rubbed it over it and sure enough it snagged the stocking. I have to laugh about all of this what's the alternative lol...the laundry gods are sure giving me trouble but it will be resolved, this washer is staying.lol.
Thank you all for your advice, obviously I trust this group of washer genius's...ill get another pic up today.
Hope you can see this, I had a devil of a time trying to get this pic, they look like deep ingraved groves that go the entire way around the tub and are rough and a test of running a nylon stocking over it did snag...is this set of groves on all SQ's...thank you
Beth they are just below the botton holes in the tubs side, but not the holes on the tub floor...I posted the pic on garden web...but for some reason here..everytime I choose the pic I want it sends the first pic
Malcolm, on the second pic they are around that shiny ring around the first row of holes along the side but mine are about 3 inches and rough enough to snag the heck out of nylons
I read another post where Frigilux looked at a SQ with these same rough groves...Frig, if your around when your SQ was delivered did it have this issue? Thank you cheryl
The roughness you are feeling is either grooving that was left from spinning (rotary forming) the bottom of the basket or it could be scratching from sanding and finishing after forming and welding. This is the unfortunate downside of a stainless basket. With the porcelain coated baskets the layer of glass covers and smooths out these minor imperfections.
The roughness will wear smooth with use but very sensitive garments could be damaged. Of course something that sensitive (Nylons etc) should either be in a laundry bag or hand washed so its not that big an issue. Dragging Nylons dry across the roughness is an overly severe test as they would be wet and floating if they were being washed. As with the rust spot any rough areas could be worked a little by hand with some fine Scotchbrite or even fine wet/dry sandpaper. You can't harm the stainless by polishing it!
Speed Queen does make a very solid and long lasting machine, but there is some crudeness there as well. They don't spend the money to polish that basket to a perfect mirror shine due to labor costs.
Hi Cheryl, yes, you can try emailing the picture to me. I'll ask my son to post it for you, as I am not sure how to from an email. I keep forgetting to check my tub to see what it looks like around the seem. I am doing non stop laundry today as my older son came back from camp yesterday. However, I can tell you that a nylon gets caught on my seem in places as well. I had my personal technician here for something else a while back and I showed it to him because at times I get small holes in mainly undergarments. He told me that, that will not catch things washing like that. He told me that he has a whirlpool and has the same issue with his undershirts. He thinks it's the cheap cotton being used these days. I now make sure to zip zippers and fasten snaps. It's mainly the same brand undergarments that it's happening to.
My mother's tenant had the same problem with her speed queen. They put a solid vane agitator in hers and her problem was resolved.
Sorry for going off on a tangent.
Great pic Beth, yes that's what I'm talking about, so we don't need to post mine and thank you. Some spots on mine I would be afraid to run my finger over with any sort of pressure, some spots are rezor sharp lol..you folks think I could buff it? I am going to watch this rust spot, I guess there's no rush with a lifetime warranty.
Yes the washer was registered online, I need to double check that as the dealer did it while we were in settling the bill.
Its good to know this is all part of having a stainless steel tub, I'm much releived about this since I love this washer.this should have been my first choice all along, you live and learn lol
Thank you all for taking the time to explain all this all to me, I appreciate all you here.
Great...Thank you Alex, I appreciate you doing this. This pic reminds me, do you see what looks like something dripping down the tub, yet it was wiped out and dry. Boy that pic shows all the flaws lol again thanks a bunch Alex
New Machine
I went by a local dealer on lunch today. Here is a pic from a machine on the sales floor. Terrible, in my opinion.
Ahh the high cost of American labor compared to the imports, they have to cut corners somewhere. Pity they picked a very visible place that is likely to piss off customers so it may be a mistake long run.
A Scotchbrite wheel like the one in the photo chucked in a cordless drill would make quick work of this issue. Of course the customer shouldn't have to do it!
Salesman
Was in shock. Said he was gonna contact his rep about it this afternoon. Feels like .microplane when you run your fingers across.it.
Malcom
Phil I have one of those wheels that came with my dremel, do you think that would work but I better make sure its a scotch bright.I think I have one for the cordless drill, I could always pick
one up probably at lowes since I need to go there anyway.
Mrb...ya I think for the price the SQ's tub looks rough, but if that's my only complaint I'm lucky after what I've been thru with new washers, and I really love this machine.
