Guess who is joining the speed queen club?
New SQ TL Washers
YAY Paul it sounds you will have a great laundry set up, I normally use my Hi-Efficiency Calypso and SQ FL washers with an older full TL washer like my Frigidaire 1-18 washer. I usually put a load of whites or shirts in one of the HiE washers and a load of say dirty jeans in the 1-18 and put the drain hose in the 1-18 from the frist washer, this way the jeans start soaking in the wash water and I usually save the first two rinses [ not the final if I am using fabric softener ] and then start the washer with the presoaked jeans.  By doing this you can wash a load for only the cost of about 20 gallons of cold water for rinsing the jean load.
The Queens have arrived
The wash tub has a gray substance on it. I've been wiping and wiping. Running through a hot wash with extra detergent now. Any better ideas on cleaning this crud out. Geez. :-) I also sprayed with Fantastic that usually cuts grease. I'm really worried.
Thanks Uriah.Glad you like your set. I'm really impressed with build quality (other than they didn't get the serial number sticker applied properly). Something tells me that there are a bunch of these machines that were hurried out of the factory because of the government order. Hopefully the mechanical operation will be okay. :-)
Did you have any problems with gray grime on the tub?
The gray stuff on the tub is polishing compound IIRC. I would try something stronger like Goof Off and then run it through a few cycles. Maybe call Speed Queen to see what they recommend.
