Happy 100th Birthday Betty Furness!
I have a power tool collection-and two Shopsmiths.Don't use them much now-but used to.Have a model 10ER and the 500.Both have variable speed pulleys for the speeds.The new 700 model has a variable speed motor.They are very good and versatile tools.Once you get used to changeover from one tool to another-it works out well.You have to plan your work around this.The basic Shopsmith can be a table saw,lathe,disc sander,vertical drill press,and a horizontal drill press.This is a very unique tool and it is good for work that would be difficult to handle on a vertical drill.You can get a belt sander,bandsaw,jointer as optional tools that are powered from a power takeoff shaft and coupler on the back of the headstock.The optional tool mounts on the coupler side of the Shopsmith bed tubes.I have the bandsaw and belt sander-work very well.I also have a standalone Craftsman bandsaw.The motor Hp on the early Shopsmiths was 1/2 hp.Later ones were 3/4 hp and 1 hp.The new 700 model is 1.75Hp 120V and 2 hp if run from 240V.The motors on earlier model Shopsmiths were from GE.or whatever brand the owner supplied.The 10 models were also sold without motor.You supplied your own-1/3-1/2 hp was recommended by the Shopsmith folks.They also made a "sawsmith" a radial arm saw version of a Shopsmith.These are more rare.Never used one.And they made standalone machines as well.The 700 is the only model currently made-and demoed at Lowes.
There is another similar machine like a Shopsmith still available-SuperShop.It is heavier and larger than a Shopsmith and has a variable speed DC PM motor.It has a wider speed range than a Shopsmith and heavier in weight.You can order those from the SuperShop-Smithy website.They also make metalworking tools such as lathes adn mills.It is said their machines are built in China to high quality standards-the Shopsmith is still built in Ohio as the old days.The Supoer Shop was a competitor to Shopsmith even from the 50's-the design of the Shopsmith dates back to the late 40's just after the war.Designed by a German invenotr Hans Goldsmidt or something like that.Another competitor to Shopsmith in the 50's-60's was the DeWalt Powershop-based on a radial arm saw.Have used on of those as a Radial saw.A neighbor to us at one time had one and he used it as a sander,drill,and jointer.You could use the DeWalt Powershop as a single speed horizontal drill or router-shaper.A lathe attachment was available for the DeWalt-you put a pulley on the motor shaft in place of the blade or other tool,and clamped the lathe to the DeWalts table.
The most complex part of a W FL was the (tumble/spin) gearbox which they soon (~1955) did away with in favor of 3 belts with intermediate idler and one-way clutch. Seeing as how it was one-way, not given to reversing.
The single-interval timer was also bottom line/price. It could support reversing contacts but then half the tumble time it would be sitting there doing nothing leaving m'lady of the house wondering WTF. Because you can't slam the wiring from fwd to rvs without a dead zone and there was only one interval, roughly one minute. Same reason a legacy Maytag sits idle between agitate and spin/drain.
Reverse Tumbling In A Front Load Washer
Or Dryer For That Matter does nothing to reduce tangling. Clothes dryers for example never tangle clothing and NO American dryer reverse tumbles, yes balling can occur in some loads in some dryers.  But real tangling is when you have shirt sleeves, pants legs tied in knots that you have to untie as you unload the machine.
My standard test load for a machine likely hood to tangle is about 20 mens long sleeve dress shirts [ this is sort of like the peanut butter in the glass test for DWs ] None of the vintage combos that I have will tangle a load like this and NONE reverse tumble.
Westinghouse did not do reverse tumbling because there was no need to do so and it would have done no good in the early slanted tub models anyway. WH largely solved the tangling problem by designing a proper true non tilted  tub washer in 1959 and that is all they and most washer manufactures have built since.
Hans is diffidently correct that by not doing the useless reversing a washer or dryer for that matter gets the job done faster.
John L.
Very interesting....
Everything one has read to date promoted reverse tumbling of H-Axis washers as giving superior results including less tangling than one way rotation. Remember when Maytag was introducing their Neptune front loader references were made to the "rope makers" of previous front loading washers.
According to my 1952 Consumer Reports buying guide:
Westinghouse L-5 Laundromat & RL-1-49: ....more than average tangling of clothes....
Now the Norge AW-204 review did not mention tangling. Neither did the Bendix B-211
