Harvest Gold Kenmore
To Westytoploader........
Yep......... it could be a standard capacity model, and definitely, it's a late 1970's model (1976-79). With exception of the color, the amount of water level settings, and the placement of the bleach/softener dispenser, that machine looks EXACTLY like our 1978 large capacity model sud saver (the same amount of speeds and cycles, but only ours was white, it had four water levels instead of three, ours had a Penta-Swirl agitator and the fabric softener dispenser was mounted on top of the agitator).
--Charles--
standard tub
It's standard. the rotoswirl would be deeper in the machine if it was the super. Or it would have a penta swirl or DAA if it's later than 1977
Quie a "deluxe" series 60 or series 70 model, look at the 5 wash/rinse combos. Most common version of this aws with only 3 temp combos and the 3 water levels and no bleash "funnel".
Does this Ebay Kenmore washer have an off-balance switch?
Does this harvest gold Ebay Kenmore washer have an off-balance switch with a buzzer?
