CB&C
First thing I made in my new PC was corned beef & cabbage!
Usually this is an all day or at least afternoon affair, not something you decide to make for weeknight dinner at 4PM! *LOL*
Purchased a brisket at local supermarket at around 5PM and had dinner on the table by around 7PM. After cooking the brisket in the PC, put my favorite glaze (mixture of brown sugar and honey Dijon mustard) on top then popped the thing into broiler for a bit to melt.
Here is a link to the model I have (Magefesa Rapid II), which though no longer sold in the United States (the company is based in Spain), you can find the set often MIB at estate sales and fleaPay.
Once you start researching pressure cookers soon enough the debate about spring valve versus jiggle top/counter weight comes up.
The Magefesa is a spring valve and have to say the touted advantages of being able to use less water in such things was not only true, but gave excellent results.
With jiggle top pressure cookers you have to compensate for the amount of steam that is released by the counter weight. Usually this calls for using "lots" of water, which in turn causes persons to feel items cooked in such things taste boiled to death.
Spring valve cookers release much less steam and safely reach a higher pressure than jiggle tops. This not only translates into faster cooking,but less flavor and such are leached out into the water.
To make corned beef my unit only requires enough water to barely cover the top of the meat.
