voodoochikin04
Hello!
Well after over a year of trouble free amazing dish scrubbing power, we finally started noticing some issues with our kds-58. It started with the tub sometimes not draining "fully". Then we noticed over the last month that the top rack was not cleaning near as good. Today after a normal wash, I found the tub was basically full, and top rack dishes were not clean. I decided to check things out.
I did find that my brass ring on the upper wash arm support had cracked but is still in place. I speculate that it's no longer holding the washarm in place and maybe the washarm is floating up during it's rotation and slowing down? I'm not educated enough on this. I pulled the wash arm support and the impeller and could not find any other issues. The wash arm spins smoothly by hand, and has just a little play when wiggling. Maybe that's too worn? At any rate I ordered a replacement wash arm support on eBay, the kind with the plastic part in place of the brass funnel looking piece.
I'm not sure what's causing the tub to not drain fully, a cancel and drain has no problem draining it fully. It's also random as too the level of water in the bottom after a completed wash. Sometimes it's at the "partial fill" level and sometimes less.
Any assistance or guidance would be much appreciated. I'm not against upgrading these parts of someone has a newer 2arm style parts available like stevet's conversion. Thanks!! -Matt
Picture for attention.
