HD Radios Getting More Affordable
Great!1Maybe now people will buy "HD" AM and FM radios-stations are installing new HD transmitters in their stations.I know of a few.One of the stations here has gone to 50Kw on their AM and are broadcasting HD as well as analog.At present stations can do this.If you are the engineer at the station-modulation levels of both the digiatl HD programming and analog programs are critical-if either is too high-will interfere with the other.If you are listening to analog and hear a Hiss that is more than normal-its the digital programming interfering.If you are listening to the digital one-and hear it drop out and come back on-esp to the program-the nanlog channel is too high.also there is another digital HD radio format-Digital Radio Mondial-DRM-it is being experimented with by shortwave radio broadcasters-the one I work at will experiment with it.You need a newer transmitter to use either of these digital formats.On shortwave--analog"FM" sound quality is possible.DRM is being used mostly by the European broadcasters.Also in many new cars their radios have HD capability.
I think I'm happier about getting the second HD station on each station position commercial-free, for nothing!
I was initially going to get a Sangean HD tabletop, because I've had very good luck with my Radio Shack shortwave, made by Sangean.
My rationale is, why not give this less expensive offering a try?
I'm curious about this digital HD radio stuff. Do the terristeral radio stations use as much dynamic range compression that they do for their audio feeds? It takes the life out of most of the music. the satellite XM and sirius services still use dynamic range compression, but even worse, they also digital data compression too, which REALLY sounds terrible because it makes the high frequencies sound like running water. I was quite dissapointed with satellite radio. I want to hear an HD radio before I'm convinced it's worthwhile to spend money on
I'm not a techie by any means, so I'm not sure this addresses your concerns, cybrvanr, so please don't laugh if this is kindergarten-level for you! It's from the HD Radio website:
"Ever wonder how technology can split the radio signal into analog and digital channels and then transmit it over the existing AM/FM bands? It’s a process known as In-Band On-Channel (IBOC) Broadcasting. It’s DIGITAL, and it’s FREE.
Digital Broadcasting
HD Digital Radio supports CD-quality sound as well as song titles and artist names. And because the digital signal piggybacks onto a conventional broadcast signal, it is free to the listener.
The Power of Free
With HD Radio, broadcasters can use the current radio spectrum to transmit free analog simultaneously with new higher quality digital signals. This eliminates the static, hiss, pops and fades associated with today’s radio caused by conditions known as multipath, noise and interference.
Transitioning Out of Analog
With IBOC-based HD Radio technology, radio receivers and other consumer electronics will receive traditional analog broadcasts from stations that have yet to convert and digital broadcasts from stations that have converted.
Current analog radios will continue to receive the analog portion of the IBOC-based broadcast, allowing for a smooth transition to a digital world. In fact, specific features have been designed into HD Radio-supported receivers to improve the existing analog reception during the "Hybrid Mode."
As the market reaches maturity, broadcasters will transition out of analog broadcasts and offer "all-digital mode". As a result of our digital architecture, enhanced services such as increased data capacity, surround sound or other multicasting solutions can be made available across this unused bandwidth."
The HD Radio set at Radio Shack is the "Accurian" and lists for $199. I read a few reviews of it, and they are generally positive, they complained there was no aux/line input and/or aux/line out on the set (I guess they wanted to plug in their iPod or something).
However I sincerely hope they don't do away with analog radio broadcasts. That would obsolete a lot of fine old collector radios, including those in classic automobiles.
