partscounterman
Since we moved into our mobile home here, I must confess that I have been running washday like an oil barron. Replaced the temp control on my Kenmore with one that has a warm rinse option and have generally behaved like my house sits on top of a hot spring. No problem with sweet & clean with all that hot water...
My recent bromance with the HE Whirlpool at my in-laws house and the POD the other day about the weird Maytag sudsaver contraption got me to thinking about some thriftier ways. I am a seasonal NPS Ranger; I should be more concerned with conservation and not be so wasteful.
So today I tried something a little different. No, I did not wash in cold water (yuck). Instead of putting clothes into the machine and filling right away, I filled my machine to the low water level with whatever water temp I would normally use and added the detergent. I let the washer run to mix the detergent and make a suds cake. I then packed my full load down into that wash liquor so that it resembled the sodden mass you see being dragged around one of the modern computerized washboards. I left this to soak for about 20 minutes while I danced to some records in the living room.
After that soak, I went in and filled the washer to the proper level with cold water. It's been so long since my washer got straight-up cold water I think she shivered a little. Then I ran the clothes through my usual wash agitation cycle. This dumbed down the water temp to the point that the bureaucrats at DOE broke out the carrot juice and rusk toast and had a little party! I figure I cut my hot water use by half and I actually like the idea of soaking in a concentrated detergent solution
Now on to a leaner rinse. I shut the washer off after filling to that same low water level I used for soaking. I then squooshed the clothes down into that cold water, let 'em all set for a minute or two and then set the machine for the drain-spin rinse-spin sequence. When that was through, I set the timer to repeat the spin rinse and spin.
To be completely frugal, I hung the wash out on the line today. I did notice some lint and the clothes were wrinkly (just like Brad & Heather's HE machine!) but everything seemed clean. My clothes aren't horribly dirty anyway, so I may keep up with at least the soak/wash part of it. If we don't get snow here soon, we may be under water restrictions next summer anyway.
Well, now that I've saved the planet in the laundry room I will treat myself to a joyride in my Cadillac DTS(jus' kidding about the joyride, not the DTS
