Heat pump dryers available in Australia
wilkinsservis
Jul 23, 2004
163
Melbourne Australia
2 years ago bought a new FL waser and heat pump dryer, both Series 8 by Bosch. Washer is the best I have ever owned despite it only using "a teaspoon of water" etc. The dryer has however been underwhelming.
By an obscure process I gave the set to my nephew, so yesterday bought another Series 8 FL Bosch washer but as a stop gap measure a vented 6 kg dryer by Electrolux. On holidays at Christmas I used a vented dryer and I had forgotten how simple quick and effective they were. I wont be staying at this apartment forever so I thought I would go "cheap and cheerful" with the dryer till the technology of heat pumps mature. The Bosch ran hot, took a long time, wrinkled clothes and seemed frustrating. What would have been the best heat pump dryer avialablle in Australia if I had gone that way?
I don't know about the best, but I have 3 "scrounged" heat pump dryers and they are quite different.
The first one is a real cheapy - a Solt from the Good Guys. I salvaged it brand new but damaged from the skip behind a store, they had dropped something heavy on it (probably off a forklift) and dented the top/side above the water collecting drawer, and thrown it out. I did some basic panel beating to straighten the top of the side panel, and all is well. No plastic was broken.
This is a fantastic dryer, works just as well as any Aussie 240V 10 amp vented dryer. I am really impressed with it. If I had paid for an undamaged one, price was under $900. Filters are well designed and easy to access.
The second is an LG with the self-cleaning condenser. I'm not sure why this was discarded, but I salvaged it and have never found anything wrong with it. The first time I used it, a blob of lint appeared in the water collection drawer, it might have had a lint blockage in the water tube that was dislodged by being thrown out, lifted into my car and carried home??? It also works really well, I do wonder about the self-cleaning condenser though, there is no easy access to it if it ever gets clogged. I gave it to my sister as she has a matching LG washer, she is very happy with it.
The third one I salvaged is badged a Hisense, which was made by Gorenje. It has a less powerful heat pump system, only uses 400 watts and is quite slow. It is officially rated at 800W but I have never seen it go above about 450W. Early on I thought is might have a fault in the heat pump (loss of refrigerant??) but now I believe it is normal, for example the towels cycle when you select it shows 3 hrs 15 min on the display, and it dries in less than that so I think it is not faulty, just a bit slow. It still does the job just fine, but I can understand someone replacing if if they were sick of it being so slow. The LG towels cycle display starts at 2 hours, and it is indeed much faster. The Hisense also has a clumsy filter built into the door, I don't like the design much. I still use it occasionally just to test it out, but I rarely ever use a dryer, I have a clothesline outdoors and more clotheslines in the greenhouse for use in wet/cold weather, so I don't really need a dryer at all.
I do have another heat pump dryer that I scrounged, but it isn't working - the heat pump works fine, but the motor won't drive the fan or drum - that is an Ariston, made by Whirlpool, it has a tiny flat pancake motor driven by an electronic controller, either the motor or controller has failed.
There was a Bosch heat pump dryer in a skip behind a store I looked at recently, the door catch had failed and some idiot had drilled the door and side panel to fit a webbing strap with click-buckle to hold the door shut, a rough and ugly repair that made me decide to leave it behind. It was also dirty and knocked around.
I take these items from the skip with permission from the store, just to be clear.
[this post was last edited: 2/26/2025-19:22]
I'm not fond of the new Miele heatpump dryers, but generally I find the current and original ones do a load in about 60-90 mins depending on the fabric and size. The filters are easy to clean and it tells you when its time. The original ones are faster, but its only 10-15 minutes difference.
In relation to creasing, I find Knit fabrics come out well unless its overloaded (Think T shirts). Woven fabrics come out wrinkled regardless of the size of the load. (Think sheets, Pillow cases and Cotton glass cloths.) For dress shirts I've only ever run them to Machine Iron and then I hang them to finish which avoids heavy wrinkles. We tend to iron all our woven fabrics (Except Sheets) but I understand what you mean, sometimes those creases become almost permanent.
Everything else comes out without issue
If it was 2 years ago and only a 1-way tumble Bosch, it might have been one of the "high speed" Bosches. Those run hotter than typical heat pump dryers - something like 70C towards the end of a cycle isn't unusual.
All ELux dryers on the Australian website appear to be the last gen ones - the ones with the heat exchanger still to the left instead of centered.
Incredible dryers, very gentle, very good on bedding.
Not the fastest but very on point drying, especially on the 9000 series.
I had a matched LG set at one point. I found that to not be the gentlest on fabrics, though that was probably down to the washer.
They dryer wasn't perfect on tangling bedding, but dried quickly (even on Eco) and thoroughly.
Gorenje and it's rebrands aren't fast, but dry surprisingly gently and well.
Quality is what it is, but they are rather cheap.
