HELP freaking Haier washer problem
coldspot
Sep 14, 2004
431
Ok this is the first I ever had this happen. Water drain pump is not working at all. Tub is full of water. How can I drain this freaking thing. Also can I replace this cheap pump with something a litter better built.
model is a hlp21n
find where the pump filter is unscrew it and catch the water in a bowl or pull the machine out pull the drain hose out of the drain pipe and hold drain hose into a bowl or bucket
look on ebay for a pump :)
That worked slow but worked. Now off to get prices of the pump. I do have a danby twin tub on backorder but need this till it gets here.
Took your tip and open the pump what I found is odd. How this even got there I have no ideal I am the only one to use this washer. Two big pieces of clear plastic and foam.
