Help Help Miele w 3725 washing machine error code f53!!!
ian_p61
Mar 5, 2011
89
Melbourne Australia
My mothers Miele HoneycombCare W 3725 Washing Machine has started displaying the Error code F53 what should I do!! What does it mean!! The machine is properly only 6 years old!!!!!!!!!
All help will be a god send!
unplug the washer then plug it back in and set Sanitize cycle. As soon as it begins,cancel the cycle. Then try any cycle again and see what happens. These washers have a severely sensitive balance system.If the load is at all off balance,it should at least attempt to get revving up. If it does f53 again, check to make sure it is firmly balanced/leveled onto the floor firmly.Try again and if it fails,email Miele cust.svce.
Tachogenerator failing / failed
Here is from the Service Manual of a W3033 - assuming it's pretty much the same failure. The model this references from has the brushless motor in it. The tachogenerator is on the back side of the motor which senses the speed and direction of the motor. If it quits working it will throw this code.
F53 code on Miele W3725 front loading washing machine
I have Technical Code F53 error & alarm showing on my Miele W3725 front loading auto washing machine. From reading this thread it is apparently a fault with the tachogenerator. Appreciate any assistance anyone can give me on how to go about fixing/replacing it please.
Is it an easily replaceable part? And where can I get one?
Many thanks.
F53 errors seem rather common on Miele W3725 washers; it could be anything from just the motor brushes needed replacement to entire tachnogenerator.
If handy DIY you can perhaps do the testing and repair job yourself with parts ordered from Miele. Otherwise you are likely looking at a very dear call out which might equal half or more cost of a new machine.
http://spares.bigwarehouse.com.au/product_info.php?cPath=86867_86869_93238&products_id=1885107
https://www.justanswer.com/appliance/87sqp-w3725-f53-fault-anything.html
