Help I am stuck
I`m sorry folks I dont type right or can put a sentence together at times
Pressure switches on a washer I`m trying to fix my Haier FL the bloody thing wont fill up right
I`m in the process of charting the 5 yes 5 adjustment screws do on the switch
Depends on the switch. If there are 5 screws on the switch, then you have more than one switch telling the machine what to do. IIRC, you have one for each: high water level, low water level, spin relay, door relay and overflow safety. Without info from the manufacturer, playing with each screw can really "screw" the machine up.
