Help! Looking for Kitchenaide Hobart KDS-18 timer
cherokee
Jun 17, 2023
4
Southern CA
Part #4162399. Cost is no issue. If a timer from a different model will work, please let me know! Our Kitchenaide Hobart Superba KDS-18 has been in our home for over 40 years and ran perfectly until now. This is hands-down the best residential dishwasher ever made. Thanks in advance for your help.
Isn’t filling with water. I replaced the fill valve first but that didn’t fix the issue. The only dishwasher repair guy I could get to come out then said the timer was the issue. Hope he’s right.
Excellent Outcome!
This is one of my favorite things about this site.
Don't toss the faulty timer.  It might be fixable by you or maybe by the guy who had the rebuilt one for sale.
Kitchenaid KDS-18 dishwasher won’t stop filling with water
I just purchased a barely used Kitchenaid dishwasher KDS-18. It’s actually the portable version witch goes by KDS-58. I fired it up for the first time to test it out and the timer seems to operate normally but when the timer gets to the point where it sends the signal to let water in the water won’t stop coming in and it will then start to overflow. Even WHEN I OPEN THE DOOR WATER IS STILL COMING IN!! I have to shut the water off manually to get it from supplying the dishwasher with water. I will the use the Cancel and Drain to drain the water. One the dishwasher is off no more water comes in with the water supply turned back on.
Has anyone heard of this happening? If so, does anyone know what exactly it needs to fix the problem?
Yes, that is correct ’qsd-dan.’ As odd as it may sound, that’s what is happening. Thank you for the response and info.
I did look this part up on eBay. It’s saying OEM Whirlpool. Will this fit my machine?
The valve will fit, I've used a couple of them on my Hobart dishwashers including a KDS-18.
The original valve is a dual inlet setup and the new valve is a single like all modern appliances use today but it functions the same. Just use electrical tape on the extra 2 wire connectors so they don't energize or short out on surrounding metal.
Inlet valve, not closing
This is a fairly common problem and one of the many problems that can occur with an inlet valve.
If it’s a lightly used machine, you can take the valve apart and clean it and it will probably start working again.
Portable KDS 58 Only had a single inlet valve as it was manufactured, KitchenAid didn’t worry about the portables flooding because the user could turn the water off so easily if it started to happen. They also were trying to save a few dollars. They also were trying to save a few dollars. The portable was already a very expensive machine.
John
John & Dan,
Thank you both for your awesome feedback! Dan, I did order the part that you said to order that will fit my KA. Thank you very much for you expertise and for getting back with me.
John, thank you for you for the info on the KA-58 using a singular valve for the portable versions. I will presume it will be a straight forward fit with the new part. With that said I’m also never the one to throw away any KA by Hobart part as I’m sure they can be fixed in some sort of way especially the timer. I will also take your advice and clean out and clear out any obtrusion the original inlet valve may have.
Thanks again guys! I really appreciate it and will update after the repair, “As soon as I find a repair manual for it. Lol!! I’m sure I’ll find one.”
KA- KDS-58
Hope all had an awesome 4th!
Another question I have about my portable KA KDS-58, I noticed that I’m able to simply remove the lower wash arm by lifting off, same with the metal fine filter screen. Is that normal? I would expect there to be a bolt or something that would secure the lower wash arm on to the filter screen.
