HELP Maytag dryer won't heat
Honestly it could be any of a half of a dozen things.  Parts can generally still be found.  Certainly thermostats and wire are easy to get.  Timers are a bit dicier but there are still some of them around.  I honestly don't know whether or not the heating element can be restrung in these if it is bad or if you need to replace the whole heater box.  Without doing a 20 minute comparison of parts manuals I can't say if this heater was used on later models or not.
Circuit breaker
Check both circuit breakers, one might still be on, supplying power to the motor, the element, but not the heater. That might happen on occasion.
Maytag fixed today
The heating element was replaced today and things are up and running once again. We vacuumed everything out, checked all of the sensors, put it all back together and it is wonderful; quiet and heating just fine. Thanks to all for helping. Gary
