Help me purchase my first washer/dryer set!
I'd go for a set of newer model Mah55/6500 and Mde/Mdg5500 (elect or gas) Neptunes. The later models already came with the updates including the motor&control upgrade among other things. You can find them used for a good price.
RCD
if it were my bucks.....
I'd definitely get the Speed Queen or F-P over the two originally mentioned. Just my preference I guess.
An update.
I don't think that geting a used model is something that will fly here, although I personally wouldn't mind.
I've looked into the FPs and what concerns me is that I see some complaints about spilling (as well as a general lack of people available to service them). The spilling is an issue for me as we're in an apartment with wood flooring in the laundry area.
If we were to get the FPs, the ONLY model washer we could afford would be the one in the link, the EcoSmart WA37TG1.
I have the GE Profile Hydrowaves on order but haven't taken delivery yet, so I'm not committed quite yet.
Thoughts?
Model that i would recomend that you buy
hello
here are the specp for the maytag washer and matching dryer hope this helps you
Good luck
Maytag Laveuse 3,2 pi3 à chargement sur le dessus
263 637 822
Information sur la marque
Voyez d'autres produits Maytag
Tableau de commande: Blanc
Coffrage: Blanc
Numéro de Sears 263 637 822
Numéro du fabricant MTW5807TQ
Veuillez préciser une quantité entre 1 et 99.
Sears Prix Ordinaire: 749,99 $
Caractéristiques
Important : Les grandeurs indiquées sont approximatives. Toujours mesurer la marchandise réelle avant de faire des plans définitifs et du découpage.
Caractéristiques Générales
Capacité Super
Capacité (pieds cubes) 3.20
Largeur de l'appareil (pouces) 27.0
Hauteur de l'appareil (pouces) 44.0
Profondeur de l'appareil (pouces) 27.0
Verrouillage de sûreté (porte, couvercle) Non
Consommation min. d'eau (gallons impér. ) 11
Consommation max. d'eau (gallons impér.) 42
Fini coffrage/dessus Acier émaillé
Matériau cuve extérieure Polypropylène
Matériau cuve de lavage Acier inoxydable
Insonorisation Qualité supérieure
Cote Energuide (kWh/an) 419
Certifié Energy Star Non
Système de lavage
Système d'entraînement de la laveuse Entraînement par courroie
Sorte d'agitateur Dual-Action
Commutateur vitesse 4 choix
Cycle énergique/durée accrue Oui
Cycle(s) courant(s) Courant, sans repassage
Autre(s) cycle(s) d'entretien des tissus Délicat, à laver main
Cycles spéciaux Trempage
Option rinçage supplémentaire Manuel
Réglage automatique de température Oui
Réglages température lavage-rinçage 4 1 réglage auto
Réglages du niveau d'eau 5
Filtre Autonettoyant
Distributeur de javellisant Distribution minuté auto
Distributeur de détergent Non
Distributeur d'assouplissant Oui
Avertisseur fin de cycle Interrupteur marche-arrêt
Nombre de vitesses du moteur 1/2 hp (2 vitesses)
Tableau de commandes
Sorte de commandes Rotatives
Mise en marche différée max. (heures) 0
Matériau Plastique
Minuteur mise en marche différée Non
Voyants de marche Oui
Informations sur la garantie
Pièces main-d'oeuvre
Garantie générale 1 an 1 an
Corrosion du coffrage 1 an 1 an
Moteur 1 an 1 an
Système d'entraînement, transmission 1 an 1 an
Panier de lavage 1 an 1 an
Cuve extérieure 1 an 1 an
dryer spec
Maytag Sécheuse électrique 7 pi3 de super capacité
263 677 822
Coffrage: Blanc
Numéro de Sears 263 677 822
Numéro du fabricant YMED5707TQ
Sears Prix Ordinaire: 549,99 $
Caractéristiques
Capacité Super
Capacité (pieds cubes) 7.00
Largeur de l'appareil (pouces) 29.0
Profondeur de l'appareil (pouces) 28.5
Sorte de porte Non réversible à ouverture latérale
Puissance (W) 4750
Puissance nécessaire (V) 240
Éclairage du tambour Oui
Grille de séchage Non
Matériau du tambour Acier enduit de peinture
Type d'évacuation 4 façons
Filtre En façade
Insonorisation Haute qualité
Cote Energuide (kWh/an) 950
Système de séchage
Nombre de cycles 6
Système de séchage automatique Capteur d'humidité
Option séchage réglable Non
Capteur d'humidité Oui
Séchage minuté avec chaleur Oui
Séchage minuté sans chaleur Non
Cycle normal pour tissus courants Oui
Cycle sans repassage Oui
Cycle délicat Oui
Cycle séchage humide Oui
Cycle anti-froissage Non
Cycle défroissage Non
Nombre de réglages de température 4
2 réglages de température Non
Averisseur filtre à charpie Non
Nombre de vitesses du moteur 1/3 hp
Grille de séchage Aucune
Matériau Plastique
Commandes Boutons manuels
Tambour de sécheuse 1 an 1 an
Translation
Maytag 3.2 cu. ft. Top Load Washer
263 637 822
See brand information
See more products by Maytag
Control Panel: White
Cabinet: White
Sears number 263 637 822
Mfg. number MTW5807TQ
Please specify the quantity between 1 and 99
Sears Regular Price: $749.99
Features
Important: Sizes quoted are approximate. Always measure the actual merchandise before making final plans and cutouts.
General Features
Capacity Super
Capacity (cu. ft.) 3.20
Product Width (In.) 27.0
Product Height (In.) 44.0
Product Depth (In.) 27.0
Safety Door/Lid Lock No
Minimum Water Usage (Imp. gal.) 11
Maximum Water Usage (Imp. gal.) 42
Cabinet/Top Finish Porcelain on Steel
Outer Tub Material Polypropylene
Wash Basket Material Stainless Steel
Sound Reduction Package Best
Energuide Rating (kWh/Year) 419
Energy Star Qualified No
Wash System
Washer Drive System Belt Gear Drive
Agitator Type Dual/Double Action
Speed Switch 4 Selections
Heavy Duty/Extended Time Cycle Yes
Standard Cycle(s) Normal and Permanent Press
Other Fabric Care Cycle(s) Delicate and Hand Wash
Specialty Cycles Soak
Extra Rinse Option Manual
Auto Temperature Control Yes
Wash Rinse Temperature Options 4 Automatic Temperature Control
Water Level Options 5
Filter Self Clean
Bleach Dispenser Auto Timed Release
Detergent Dispenser No
Fabric Softener Dispenser Yes
End of Cycle Signal On/Off Switch
Motor Speed (hp) 1/2 HP (2 Speed)
Control Panel
Type of Controls Manual-Rotary
Maximum Delay Time (hr.) 0
Material Plastic
Delay Start Timer No
Operating Indicator Lights Yes
Warranty Information
Parts Labour
General Warranty 1 Year 1 Year
Cabinet Rust Through 1 Year 1 Year
Motor 1 Year 1 Year
Drive System/Transmission 1 Year 1 Year
Wash Basket 1 Year 1 Year
Outertub 1 Year 1 Year
Maytag 7.0 cu. ft. Super Capacity Electric Dryer
263 677 822
Cabinet: White
Sears number 263 677 822
Mfg. number YMED5707TQ
Sears Regular Price: $549.99
Features
General Features
Capacity Super
Capacity (cu. ft.) 7.00
Product Width (In.) 29.0
Product Depth (In.) 28.5
Door Type Non Reversible Side Swing
Wattage (W) 4750
Power Requirements (V) 240
Drum Light Yes
Clothes Rack/Bar No
Drum Material Painted Steel
Venting Options 4 Way
Filter Front Mounted
Sound Reduction Package Better
Energuide Rating (kWh/Year) 950
Drying System
Number of Options (Cycles) 6
Auto Drying System Moisture Sensor (Better)
Adjustable Dryer Option No
Moisture Monitor Yes
Timed Heat Yes
Timed Air No
Regular/Normal Cycle Yes
Permanent Press Cycle Yes
Delicate Cycle Yes
Damp Dry Cycle Yes
Wrinkle Prevention Cycle No
Wrinkle Release Cycle No
Number of Temperature Options 4
2 Temperature Staged Drying No
Lint Signal No
Motor Speed (hp) 1/3 HP
Dry Rack None
Control Panel
Material Plastic
Controls Manual Knobs
Parts Labour
Dryer Drum 1 Year 1 Year
Good luck
I think you'll be fine with the Hydrowaves. GE's dryers have a nice, big drum, too. One of our members, Jamie (Pulsator), bought a Hydrowave recently, and his reviews of it have been good.
It's heresy to say this around here, but unless you are willing to deal with locating parts and---depending on how old a machine you get---servicing it yourself, a new machine is probably the way to go. I agree that vintage machines were built for the long haul compared to new, plastic model; but for many people, getting a new washer is the more practical choice.
While I think modern front-loaders are better than modern top-loaders, if you are on the third floor of a building with wood floors, a front-loader may cause too much vibration and shaking, anyway. Getting a top-loader may be your only option.
Let us know how things work out with your Hydrowave washer. We love to read reviews!
Well, I'm going to go with and take delivery on the Hydrowave set.
I'll be adding a repairmaster five year extended warranty to hedge my bet.
I really want to go with the fisher paykels but I've read too many just out of warranty horror stories to feel confident in purchasing them.
Consumer Reports reliability ratings show that Fisher/Paykel are more repair-prone than Whirlpool/GE/Frigidaire top-loaders. Glenn (Dadoes), however, has had two F/P washers and never experienced a problem with them. It's really the luck of the draw.
Hope you like your Hydrowaves---especially since I've been the one nudging you in that direction, LOL. Let us know what you think of them once they're installed.
Thanks, Frigilux!
I'm just happy that we'll have a washer and dryer in the apartment.
I never realized what a relatively stressful situation simply buying appliances could be.
Hopefully I grow to love these machines.
A little late to the gate
The customers I've sold HydroWaves to are happy with them. Very quiet machines - usually you just hear the water sloshing around. Yours should come with a DVD, watch it. It 'splains (as R. Ricardo would say) that after the machine fills, it pauses and you'll hear clicking. If you lift the lid it re-sets and starts clicking again. This is just the cycle advancing, if you keep lifting the lid it will keep resetting. Be patient and machine will start. GE may have modified this by now, my factory rep said they got a number of repair calls for this.
The sensor dryers sometimes have trouble with "mixed" loads, like if you wash tees with towels. Tees will be dry but towels wet, or towels will be dry and tees fried. Try to wash similar stuff and you'll be fine.
Happy laundry days ahead!
The Frigidaire 2140 has a large 3.5 cu ft capacity but stays on the standard 27 x 27 inch footprint. Larger washers get the extra capacity by being deeper, which may not work in closet installations or in laundry rooms with tight clearances.
Best Buy usually has it on sale for mid-500s, OR they will raise the price to 600 but give you 100 dollars off if you buy a dryer too. This week the pair would cost you 1000 for electric dryer, 1069 for gas dryer. This pair can be stacked ($25 bracket from Frigidaire) to save space if you like.
Sometimes Best Buy lowers the price down to 549 for the washer but eliminates the 100 dollars off for buying a pair, which would be beneficial to someone buying only a washer. Lowes also carries this machine
and sometimes puts it on sale. Currently going for 548. The matching dryer is 499
and remember you may not get any rebates with a TL, so do your homework before making a purchase. The rebates may place a FL pair within your reach.
Frigidaire makes stacked combos with gas or electric
but these cost more than buying separate machines.
I have had my 2940 for two and a half years. Great cleaning, quiet operation. Depending on where you live, you may receive rebates from the water district or gas utility (in my case, $100 water rebate, $35 gas utility rebate). Will cut your water use by about 60-65%. Because the clothes are drier after final spin that in a TL, drying times are reduced and this will result in lower gas and/or electric bills. If someone in my area (SoCal) needed a new pair, after the rebates the net price would be 865 for electric, 934 for gas.
Front Loaders...
...are the WORST choice that you could make. They are very unreliable, NO ONE wants to fix them, and they don't wash well....which is why it can take three to four times LONGER to complete a cycle, compared to a top loader. Go get yourself a set of Speed Queen top loaders. Mark
Um...in his original post, he stated that his budget was $800-900 maximum. Are Speed Queens all that inexpensive? People who recommended FLs here were trying to point out that some moderately priced machines may be more affordable (if bought on sale and if rebates are offered) than he realized.
Yes, FLs take longer to wash a cycle, because they involve multiple rinses with low volumes of water. But they also rinse the clothes very clean, leaving far less soap residue than my old TLs used to leave. They also use far less water, which in some areas (California, where I live) is important, since we have to conserve water. Water use may not be an issue in Virginia , but it is here. Conversely, A/C operating costs may be an issue in VA but not in coastal CA, where no one on my street even has A/C, nor do they need it.
I don´t have any problem with my american FL.
Actually my affinity saves water, detergent and electricity.
I can wash bigger loads than in a standard top loader, they come out cleaner and much better rinsed.
I recommend High Efficiency Front Loaders from Electrolux (frigidaire) or Whirlpool (Maytag, Amana, KA, etc...)
All of them has their positive and negative points. you just need to choose the model you like and the model you can afford.
Other tip I can do is... hear your feelings.
You can be at the store, in love for brand A, but you decide to buy the brand B because a friend told you... You'll never be 100% satisfied.
Buy the washer YOU like!
just seems logical....
.... to buy a machine that can be fixed. SQ machines are the same design used for about 25 or more years. I've never had good results with a front load machine. They don't wash well, they take FOREVER, and who fixes them when they break down?....and they wrinkle everything up terribly. Use a little more water and get your clothes CLEAN! Mark
CB, if you aren't confused enough by now, may I suggest just washing your clothes in the bathtub or better yet showering with them on and walking them air dry.lol. No, just go Kenmore basic.
There's nothing wrong with front loaders or top loaders!
They both can wash well, rinse well and be equally as reliable. It just depends on which one you get as to how good it is.
Personally I couldnt deal with a 1 rinse top loader. I prefer my clothes not to be full of detergent residue thank you =]
If top loaders are so much better how come front loaders have always been more popular in Europe, even before the eco-freaks started dictating what we're allowed to do?
A front loader with a heater will wash perfectly, I've never used one without, we don't have them here. This is the only reason I can think of as to why American's seem to have problems with their front loaders.
If you wanna be eco-friendly, don't bother chucking your top loaders for front loaders, or wash in cold water. Just ditch the drier for a washing line and a drying rack. Dryers are about the most energy hungry appliances in the house and they're totally unecessary!
People "washing" their clothes in cold water in their modern front loaders whilst their dryers are rumbling away beside it and their A/C is running at the same time really are fooling themselves into thinking they're helping the environment.
i hace a kenmore washer and dryer and ther work great
dont let its size fool you it can fit ALOT
it uses very little water and gets the clothes clean it would make a great first washer and dryer
it will last a long time
fwiw...
My parents just replaced a direct drive kenmore, 8 years old and not worth fixing, with a nice MOL Speed Queen unit. We have a damp basement where the machine is to live and wanted something mechanical and overbuilt, not electronic. The new machine doesn't have a ton of features, is as dull as dirt to watch but its rock solid and does a great job. I wouldn't be surprised it if it lives for 20 years. Closest thing on the market to the center-dial maytags, from what I've seen. Cost a little more than the kenmore it replaced, but not much.
In your place, I would buy a new Speed Queen washer and grab a basic dryer off craigslist. Kenmore dryers are usually easy to find and dirt cheap.
