Help needed: J-B Weld for an oven
donprohel
Silver Member
Aug 14, 2010
488
I live in Munich - Germany, but I am Italian
My crappy Siemens ventilated oven has a problem: the oven fan “rattles” because is it not fixed to its axle.
For what I have seen, there is not a strong or fixed bond between the fan and the axle (crappy design…) it seems that the fan is not held by the bolt (I hope this explanation is understandable).
I am thinking of gluing the fan with a J-B Weld epoxy that should withstand 300 °C (572F); the oven itself cannot go higher than 250 °C (482F) the mechanical stress is minimal, I just need to keep the fan in place.
What do you think? Is it such a stupid idea?
The J-B Weld epoxy is in the link, it seems to be a German version of some other J-B Weld epoxy.
https://www.amazon.de/-/en/Adhesive...=1640168959&sprefix=b00hxsl25y,aps,428&sr=8-1
Hmmmm- got me thinking-
My oven has developed some rust through spots and I can see the hidden element through them, seem to be getting bigger.  I'm wondering if the high heat version of JB weld might work to fill the small holes, rated up to 1000 F.
This is my fault since I used the oven as a steam oven for a number of years.  I had thought there was enough heat in the oven to dry up the steam but apparently not.  It's a fine oven and hoping to find a way to fix the issue.
