kevin313
This past weekend, I finally put into service a range that I rescued a few years ago, a 30-inch white Frigidaire range with wonderful French doors. The range was filthy - grease everywhere! Every evening for two weeks I cleaned a little section at a time, checked all the wires, replaced all the gaskets, light bulbs, etc.
I plugged it in and everything seemed to work (including the clock!) - but there are two issues:
1) One of the six inch burners will only work in "Hi" or "Simmer" - none of the middle settings will get it past luke warm. Is it the radiantube? Or is it the switch?
2) The oven (which does not have the original bottom bake element, but a replacement) runs about 50 degrees hotter than where you set the dial, and then when you open the door to take something out or check on something, the temp falls and doesn't come back up without increasing the temp setting. Any ideas?
If anyone has any info on this range or has any suggestions as to what I should check, I would greatly appreciate it!
