I was installing that 1999 Maytag E.Q. Jet-clean dishwasher and it worked just fine
for 30 seconds then BooM. Sparks ,Ozone ,I got the hell shocked out of me bad.
I had the dishwasher not all the way in I wanted to let it run a rinse cycle and
make sure there was no leaking.
When I Shut the door and grab the bottom frame part and pushed it, I saw lighting , got the hell shocked out of me ,it cut the power off about half the house.
Every surge suppressor got torched bad , they smelled like burning plastic and two of them are the big expensive ones that you put your cable into and out of also.
My P.C. got fried but it was on a really cheap one , I forgot to use the good one on it.
My Heat pump and water heater work fine .
My 120 lines some of them are reading like 81 volts. My T.V. and wi-fi router works fine , my fridge works fine.If I turn on my coffee maker the lights go really dim and the compressor on the fridge turns off.
Every one of my CPFL Lights the ones that didn't get fried are like flickering and dim.
My Washer will fill up but once the motor starts the lights go really dim and the motor is having problems .
I turned it off .
I found out what caused it. The power wire for the dishwasher got caught up in the scissors like metal door hinge in the back and it cut the wires and grounded them out together .
I have a Electrician coming tomorrow but, I was wondering if anybody in here has any ideas about what happened?
I don't have any problems unless there is some current being pulled ,Vacuum,Coffee, and then everything goes strange.
I turned it off .
