Yes, I can confirm that
Here's a screenshot of your service sheet - the settings for the oven temperature control.
That there is only an 'L1' and not an "L1" and an "L2" suggests a super simple control (more options with both, but irrelevant as rarely implemented).
The PL means Pilot Light, so you should have a light which comes on when heating and goes off when the temperature in the oven has been reached?
The BK is the bake element.
The BR is the broil element.
As you can see, there is never an "X" in both columns for BK AND BR at any time, just for PL and one or the other, separately.
This is confirmation that we are not working with both elements in tandem, either in series (110V) or parallel or something else.
Here are two other things to check, not that I consider either likely:
a) Could it be that your house voltage rose to 220/240V from 208V? Your utility company could tell you. It wouldn't make that big a difference in heating times, so you might not notice it, but it would definitely lead to shorter baking times - and that could result in lessened browning.
b) Is it possible that a seal between the door and the oven is gone or has failed, or the door has slightly warped, reducing the heat at the top? Or, truly unusual but trying to think out of the box, did the door or the seal get tighter, and there's more moisture in the oven or a shorter baking time?
Try this. Bake some cookies, spread out as far apart on a baking sheet from each other as possible on the rack height at which you usually bake. Do they all come out evenly in the baking pan?
