tkrego
Hi!
I purchased a 1956 ranch home with a vintage GE range. My model number is 1J408G1N1 which is the turquoise green color. That info shows it is a 1956 GE Liberator. I was able to purchase PDF's of the user and service manuals online.
The unit is in good shape, we use it every day. I don't know if we will be able to keep it. My girlfriend prefers gas and gets frustrated with the quirks of using an electric range.
My girlfriend is afraid to use the Automatic Calrod surface unit, and I'm not sure how it really works myself. The dial to turn it on is tricky, as it seems to always be on and will heat up with nothing sitting on the element. For now we don't use that element. I've read here that they may not be fixable if broken, though I don't know how to determine if it does work.
I was looking to purchase replacement Calrods, but I'm not sure what the exact model to get since GE has used the same numbers for decades. I think they are the low-profile with an attached trim ring.
What determines the wattage of the Calrod? I've seen 2300 watt units, but the service manual says my element is rated at 2600 watts. I've seen close (exact?) matches on eBay, but haven't pulled the trigger since I'm not sure what I should be getting.
How do I verify if an element is working correctly? The right front element doesn't seem to get as hot as the other large element.
I also have the griddle that plugs into the stove top, we tried to use it once, but it didn't seem to heat up to be usable. I don't know if that was user error on my part, or something related to the Automatic Calrod.
I may end up having to get rid of it. We have a brand new GE JGB750EEFES range that's been sitting in the garage for two years. We don't have a gas hookup in our kitchen and that has delayed getting rid of this classic. For now.
Thanks for any help with getting this back in shape.
