this is what i have accomplished tonite on this leaky 1-18.
have included pics here to show progress.
top nut came off very easily and pulsator removed easily also.
i took out inner tub as well, to give me a look at the outer tub and to get more room to work. i guess when i get down to the hub nut i will have to have inner tub back in to hold it while i attempt to turn nut, or will i?
my main question here is;
HOW DO I GET THAT WATER BELLOWS CLAMP OFF? i read on the web that if you don't have the proper pliers that large channel locks will do. i don't understand what i should be doing? do i have to squeeze the clamp to get it to unlock? at first i thought it was under spring tension to squeeze shut and i had to pull it apart but now i'm thinking it is locked and by squeezing it inward it will release lock?
is it true i could use a worm clamp instead like someone on the site suggested when i put it back together?
bellows looks good actually from what i can see. this is a very good lession in 1-18 engineering for me! would appreciate you frigidaire guys helping me here!
thanks, now here's the pics!
top nut came off without a hitch! used vise grips to hold pulsator shaft from below, clamped them to that big knob on it's base.
