Help With Paint for Maytag A608 & DE608
mayken4now
Feb 3, 2005
2,555
Pensacola, Florida
Hi folks. Does anybody know where to get the "Sunglow" paint to do the control panels of these Maytags. If I am not mistaken, the color is the Sunglow. It is the sort of bronze or golden color. I have gone to hobby lobby and looked in the model section, but am not sure and don't want to buy too many paints to match. Anyhow, looking for clues as to where can I get this color.
Thanks!
Steve
Obvious
Ok I will, but yes, and they don't know or have the paint. I go to the local Maytag dealer here in Pensacola all the time. He says he cannot order it.
Steve
Beautiful Machine
Sorry can't help with paint.
But can't help noticing that there is no visible timed dry option. Does air-fluff default to some sort of a timed interval?
Does this machine still have the filter in the back of the drum as the earlier vintages had?
Tks,
Steve
Re: Paint Info:
Hey! Mayken4now/Steve, what about checking with an Automotive Paint place? Another suggestion is can you take that piece apart, if you can what about checking with Home Depot, Lowe's or some other Paint Store, where they can Custom-Match Color's? If you can't take the Panel out very easily, maybe you can match by a Color Photo, take it to get the Custom Match, it might come out slightly different than the original, but it should get a pretty close match.
Peace and "Good-Luck" with your search for the Paint, Steve
SactoTeddyBear...
Steve/Toggle
We had the previous dryer to this one, a DG502, and it did not have a conventional timer, just the programmed settings, and no time section. The AirFluff on Maytag dryers woould just run for 10 minutes. (back then). Damp Dry was 5 minutes, on high heat. Regular ran about 35-45 minutes, and worked perfectly. The Permanent Press setting ran a little cooler, and had a longer cool-down.
Lawrence/Maytagbear
Works the Same as Halo-of-Heat
There is no guess work to go into drying. This dryer practically thinks on it's own. It is all about the Maytag Censor for moisture in the fabric. No hot spots to burn your clothes. We have Air Fluf, Damp Dry, Permanent Press, Regular, all think and have a distinctive DING (like an order up bell) when it is completed it's task. In addition, there is "Low Heat" and "Normal Heat" selections, then Normal Dryness and Extra Dryness that will accompany each of these two settings. It is a wonderful peice of the Maytag family. Her Washer the A608 is the most faboulaous as well!!!! We do laundry all the time and let the neptunes and HE3T's set idle. LOL
Steve
ps Thanks for the comments and help.. Sacto you are great for suggestion! Thanks to Maytagbear, and Toggleswitch(would that mean superior coach buses student lights toggle with or without amber!!!? LOL)
I just used krylon, Clean well before painting, I used a toothbrush to scrub it good. Good luck!
Hi Mayken4now
Hi Steve, Steve here.
Thanks for your insights. Not following amber light drift.. but feel free to discuss off-line using my email address. [I will read again when I have some coffee in me. LOL It's 7am Sun. morning!] There is a very funny explanantion of my screen name but not eliglible to be posted!
Back to the thread...
the lack of other settings on the subject dryer's electronically- controlled termination, caused me to think of the dryers I have used with sensors. I found them to be inacurate, in general. [Although, come to think of it a family member's newer Maytag does work well.] I personlly got a dryer without an electronic sensor and went with "fabric-master" [Sears terminology?] thermo-mechanical automatic cycle where the timer advances only when the heat is off. As you may know the heat is nearly always "on" at first, then tapers off as the clothes become more dry.
The change of phase of evaporation (turning liquid water into a vapor)takes energy and cools the dryer drum, keeping the heat "on". This is similar to an ice cube changing phase from solid to liquid; a great deal of heat is absorbed in the process.
BTW - again where is the lint filter on this puppy; rear of drum or int he front?
Tks
Filter
The line filter is right inside the door. I will post a pic or send it to your email so you can see it. It is hard for me to post pictures on here as my camera/computer illiteracy prevails.
drmitch - which color of krylon? did you do the same color on Maytag?
Steve
inaccurate sensors
"I have used with sensors. I found them to be inacurate, in general."
CR found the thermostat controlled automatic dryers tended to overdry and preferred the automatic sensors. Some electronic sensors do work better than others. Over the years I've found the automatic sensor in my '78 LK to work almost perfectly with every load of clothing on the "standard" setting IF I separate the clothes properly i.e. light cottons like sheets, pillowcases and shirts are NOT dried with heavy cottons like jeans and towels. Depending on the mix, the dryer will either run until the heavier cottons are dry, therefore overdrying the light stuff, or shut off when the light itmes are dry, leaving the heavy items damp. The only two exceptions I've found where I have to use a different dryeness setting than normal is heavy jeans, where the seams don't get dry unless I set the More Dry controls one button up from standard, and synthetic things like polyester, nylon, and that type of stuff, where smetimes the dryer will shut off before the items are dry even when set for Maximum Dry. Then I set it for the 20 minute "Touch-up" timed cycle to complete the drying.
You will note that the Maytag doesn't give you the option of a "dryness level" (other than Damp Dry) on it's cycles like other brands do.
dryness sensors
Additionally, I've had the same problem with training people not to keep "checking" the dryer to see if a load is done as I do with getting people not to pre-rinse dishes before putting them in the dishwasher. They just seem to have a hard time believing that the dryer will actually stop at the right time.
Re-visiting the "pre-rinsing" thing with dishwashers that we had in another thread sometime ago, does anybody know someone who takes clean dishes or glasses that have already been through the dishwasher out of the cupboard, and running a splash of water on them before using them?
Going to get Paint Today
Will let you all know, and thanks for all the suggestion!
Took Sacto Teddy Bear's advise, by taking a close up picture to try and match color that way. I will be leaving in a few minutes and am counting on success. If I have to, I will remove a panel and take it with me.
LOL Imagine the cracked faces when I walk in to one of these paint places or hobby stores with a washing machine control panel. Can you all just hear them when I am gone, is it my own insecurities? I usually don't give a damn what folks think about my washing machine and applicane dreams!
Steve
Success with Console Paint!!!!
Ok this is what I bought today, painted and tell me what you all think!
Golden Fluid Acrylics - Color is Iridescent Bronze (Fine)
Thanks and I am so happy!!!
Steve
Beautiful machines.. enjoy
Quote: "...does anybody know someone who takes clean dishes or glasses that have already been through the dishwasher out of the cupboard, and running a splash of water on them before using them?"
Sort a necessity here...
Here in New York City, people in high-rises and older wooden frame buildngs (read "all buildings!")are succeptible to roaches.
Their droppings are everywhere and are considered to be ordinary dust. Said to be a major aggravator of asthma.
Allergists in the area test routinely for it.
Solution: Boric acid (powder) from drug store and a bit of sugar. Raoches eat it and it gives off gas when wet. They can't pass gas (forwards or backwards!), so it ruptures their blood-vessels. Problem solved. Not toxic to humans but keep from pets. CAN be put next to dishes. Tons safer than insecticides.
Enquiring minds want to know.. LOL
The link is pushing roach product. Refrain if you really don't want to know!
http://www.roach-killer.com/
Center timer Maytag set
Very nice job Steve. And your machines look to be in MINT condition too! Keep up the great work,and take care of those babies.
Rick
Paint at Michaels
Ben, you asked where did the paint come from. There is a place here in Pensacola called Michaels. A hobby type store. That is where I found it.
Thanks to all who praise my machines. They are special and are in perfect shape inside and out. In the near future, I will post some pics on the "Imperial" setting with the panels off so all can see this!!! A lot of fun work went into the restoration!
Steve
boric acid
"Raoches eat it and it gives off gas when wet. They can't pass gas (forwards or backwards!), so it ruptures their blood-vessels"
Dis-advantage, it's toxic to pets.
That's not the way I heard boric acid kills roaches, I heard it removes the waxy coating from their bodies and they lose moisture and die. Maybe it does both?
Re: Re-Painted Maytag Panels:
Hey! Steve, great job at Refinishing the Lower Panels of your Maytag Washer & Dryer Consoles. "BTW" Michaels Craft Stores are all over, we have several Stores here in and around the "Sacto" area.
I don't know if I would have ever thought about checking out a place like a Craft Store, for some Paint to use on an Appliance. I guess if you let someone know that works at them of what you needs are and if they know their products real well, they can recommend something if they believe that their product they sell will work for what your needs are.
I agree with "Mom" Venus, your Machines look like "Show-Room" Original/Fresh, without any use on them at all. Keep up the great work and sharing as much as you have, it is always great getting to see/know the progress of projects everyone is working on.
Peace and Happy Washing, Steve
SactoTeddyBear...
Cannot Pass Gas
Think you may be thinking of rats not roaches.
Rats cannot vomit, so classes of rodentcides have been developed that amoung other things when ingested cause the rat to "vomit", but since it cannot, the rodent dies chokes on it's own vomit.
This method of rat/rodent control works well since humans, dogs and cats can vomit, thus the chances of a death by this method of poison is lowered.
On the down side, rats are VERY smart creatures. If they eat something that makes them sick, they will avoid it in the future. More over they will mark it with urine so other rats will avoid it as well. IIRC the term is called "bait shy", and it is the reason why chemicals are used that will allow a rat to consume a leathal dose in one feeding.
Squeek, squeek
Quote From Bugs Bunny:
"Look lady, I'm not a baby gorilla, I'm a rabbit. Technically known as rodentus rabbitus."
Launderess
Paint in the Blue Shade
SactoTeddyBear/Steve - an all other Friends:
You mentioned that Michales is a nationwide charin store. Great, maybe it will help others who need some sort of paint on the precious appliances.
Did you say you have the sort of blue Maytag lower panel on your machine? I bet if you need some paint, they would have it. I can fill you in more on the type of brush to use. Well, it just needs to be an artist brush with rather stiff/course bristles. I found that to work the best. I have the blue one as well, so maybe I can try to find some paint for it, although it does not need it.
Again, Thanks to all the applianceville folks who participated in my painting project.
Actually, Maytag should pay me, LOLOLOLOL the machines came out so nice. The color is just slight brighter and darker than the original, and looks better! Sorry Maytag , I hate it for ya!
Steve
