What's best???
<h2> </h2>
<h2><span id="When_to_wash_towels_in_cold_hot_or_warm_water">When to wash towels in cold, hot, or warm water</span></h2>
<span style="font-weight: 400;">As earlier stated, towels are meant to be washed in cold or warm water. </span>
<span style="font-weight: 400;">But, does this mean that we are never to use hot water on our towels? </span>
<span style="font-weight: 400;">Surely you must have come across a label on some towels that reads “hot water-friendly,” what then do they mean? </span>
<span style="font-weight: 400;">There are specific times when you might have to choose a different water temperature like hot water for instance, over the ideal cold or warm. </span>
<span style="font-weight: 400;">Hot water is perfect for your towels to get soaked in when they are extremely dirty and heavily infested with germs and bacteria. </span>
<span style="font-weight: 400;">How do you know your towel is contaminated with germs? </span>
<span style="font-weight: 400;">Various research has proven that a bath towel most especially, is home to over 80% of bacteria and disease-causing germs. </span>
<span style="font-weight: 400;">The more you use a towel without washing it, the more germs you collate, and the more the towel fibers are rendered useless. </span>
<span style="font-weight: 400;">When your towels get to this point, what it needs goes far beyond just a cold or warm water wash. At this point, the towels are actually yearning to be rejuvenated. </span>
<span style="font-weight: 400;">Hot water helps in loosening the fibers by softening the ingrained dirt clogging the pores. Asides from that, it kills the bacteria and germs and expels that damp odor.</span>
<span style="font-weight: 400;">On the other hand, cold water is perfect for a first wash and subsequent weekly wash. </span>
<span style="font-weight: 400;">It is advised that you wash new towels before even using them. This you are to do with cold water and a very tiny amount of detergent. </span>
<span style="font-weight: 400;">Cold water easily removes every form of dust or debris and wash towels clean. </span>
<span style="font-weight: 400;">Warm water can be used to treat towels periodically and rid them of day-to-day bacteria.</span>
<span style="font-weight: 400;"> </span>
<h1><span style="font-size: 12pt;">Tide Hygienic Clean and Bounce every third washing.</span></h1>
<h1><span style="font-weight: 400; font-size: 14pt;"> </span></h1>
https://tauwel.com/should-towels-be-washed-in-hot-water/
<h2> </h2>
