Here we go... Best Toilet?
mrb627
Sep 12, 2001
5,130
Buford, GA
Been looking at toilets today. Anyone have any insight or recommendation?
Considering the American Standard Cadet III
Malcolm.
WHATEVER You Do....
....Do not buy any unit that has a square-backed bowl.
A square-backed bowl is one that is oval at the front, but squared off at the rear of the bowl, instead of completely oval as most bowls are.
The problem - and hoo boy, is it a problem - with square-backed bowls is that solid waste hits that squared-off area and leaves, ahem, a streak. A big streak. EVERY time.
I have one now (rented house), and I would undertake hand-to-hand combat to prevent anyone from installing another one in any place I live in the future. Here's a sketch; if I got the clockwise/counterclockwise thing wrong, forgive me:
Check out Kohler, they have a very comprehensive website. Their best non-assisted flush action is the Class Five. Toto is also very well respected for good flushing; I know a few contractors who will install nothing else as they have fewer complaints with them. I once had a project where the interior designer specified some very pretty Porcher toilets for all the primary baths. The owner hated them as sometimes he had to flush twice. The designer then left town for an extended vacation before the guest wing was renovated so I specified Totos for those baths, which served not only the guest bedrooms but also the media room. The owner loved them as they flushed so much better than the way more expensive Porchers.
Other considerations are height (Kohler "Comfort Height" toilets are a little higher than normal) and bowl shape. The latter will be either round or elongated, with the elongated bowl extending farther out in front to a more elliptical curve than a regular round bowl. This doesn't mean anything to women but for guys the elongated bowl is handy and reduces stray drips. Check your rough-in too, this is the distance from the wall to the waste hub in the floor, most are 12" but there are some toilets for 10" rough in.
If this is a job requiring permits make sure you know what water consumption your municipality requires as the building inspector will check that out. And don't assume everything on a website will be in stock locally; you'll need to call around for that. At the same time you can look into real-world pricing as most plumbing supply companies will happily beat list prices on common brands.
Ah, this is one of those purchases that requires, shall we say, a "test drive" to really make an informed decision.
Unfortunately, Home Depot and others now mount their display models well out of reach to discourage such behavior.
As Hydralique stated hight is very important. We had to replace the toilets in this house because of that.
When we bought this house we knew that something just wasn't right when we used the toilet. Our last house had slightly taller than normal height. I measured the toilets we had in this house and the height between the floor and toilet rim was only 12 inches! Who were these made for anyway?
We found that the positioning of the internal "plumbing" wasn't quite right with these toilets and we ended up with two American Standard toilets. The height of these are 17" and we feel so much better after using them.
Never knew that about the square back toilets. Glad we didn't get any of those.
Have been using Toto toilets for many years. Very good flush and have been trouble free. Kohler has improved its Wellworth line and now is a good second choice if cost is a factor. American Standard has quality issues and would not recommend this brand.
Kohler is what I bought
I redid my bathroom awhile back and had an awful experience with the brand that went with the sink that I bought. I wanted a victorian look seeing that it goes with my 1897 house. I liked the sink so bought the toliet to match. It had a small opening and would not flush all of the contents away. I took it back to Lowes and they exchanged it and ordered a comfort height Kohler in a period style that I liked. The Kohler gets my vote and if you need parts, which I haven't needed thus far; they are made in Kohler, Wisconsin. Happy flushing. Gary
This will sound like bragging but at one recent workplace the 'standard' toilets caused my dangly bits to go for a swim. I had to use the 'handicapped' to sit down without a cold surprise. You don't want your soldier swimming in poo water.
They are getting much better at making low-flow toilets work. The last 2 I had (1.6g, 1.28g) worked perfectly. The 1.6 was American Standard and the 1.28 is... I'm not sure, the only "word" on it besides "made in China" is "Seasons". It has the pee flush, very short. If you hold the handle it more than doubles. Which is better for the plumbing when there is a load of paper involved.
What they've done is double the tank orifice area so much more water goes down in the same time as before. And lengthened the siphon so there is more suction. I see no reason to buy 'assisted'.
One thing that bugs me about Kohler, American Standard and Toto is their chintzy glazing. On the models I examined, all were unglazed on the underside of the rim. You can feel that is rough by running your finger under the rim. I think that glazing in that area keeps it cleaner, and it is easier to clean.
I was also disappointed about the poor quality of the ceramic molds on one particular model of American Standard (made in Mexico). All of the samples I examined had substantial "flashing" around one of the mounting holes from the tank to the bowl. It caused the rubber washers or seals to not mount evenly. I was afraid that might lead to leaks down the road. I could have ground off the excess ceramic with my Dremel, but why should I? I purchased two; both had the same problem so I returned them.
At Lowe's, they carry a brand called Penguin, which is made in China. It is an inexpensive toilet as compared to the name brands, but I was impressed by the quality. The underside of the rim was glazed, as was the inside of the trap. I purchased one and it has given us good service for a year now.
Square back bowel-not only streaks--but prone to CLOGS as the solid waste hangs up on the square parts-be sure to have your plunger beside these potties.I am hanging onto my "antique" water hog potties.
Rough In
One bathroom has a 10" rough in and the other has a 12.
Test drive is a problem. The unit needs to operate and be quiet to boot. So, good luck with that.
I could reuse the existing units, but hate them with a passion.
Will take a closer look at the Kohler line up tomorrow.
Malcolm
Installed a Cadet 3...
...here in 2008, and have been totally pleased. The flush is powerful and clears the bowl first time, every time. Never have to do a second flush.
This may sound odd, but house company always comments on the flush, the first time they use the fixture.
I normally don't make recommendations, but in this case, I would give the Cadet 3 a thumbs up. Trouble free service these last five years.
Joe
Has anyone ever lived in a high rise? When I lived at McClurg Court in Chicago when you flushed the toilet the waste was gone in an instant in a very loud and noisy large rush of water. Just amazing.
Most high rise and large office commercial buildings the toilets have compressed air assisted flush.A blast of air and water go into the potty when you press the flush lever.Air compressors provide the air for these-or they can run on the air compressors for the buildings pneumatic thermostats.The building I work in has this.
Here is what Consumer Reports says:
American Standard model Champion 4.2002.014---top-rated with score of 85. Super-quiet gravity flush.
Gerber model Avalanche 21-818 with score of 83. Also super-quiet.
I have a Gerber pressure flush which was near the top of the ratings when I bought it 7 years ago. Gravity flush toilets have improved substantially since then, and have surpassed the pressure flush models. Get an elongated bowl version. Very comfortable.
[this post was last edited: 5/12/2013-10:26]
We're suffering that too.
We have three bathrooms in this house and the contractor installed awful "Glacier Bay" toilets. They break, leak and clog frequently.
As an experiment we had a good plumber install his choice of toilet.
He installed a GERBER in one room. We are very satisfied. Don't know the model.
We have two more rooms to go therefore I asked a contractor-friend what are his favorite toilets.
I don't remember the brands but kept using descriptive watery names like Avalanche, Hurricane, Tsunami etc...
I installed an American Standard Clean Cadet 3 last summer.  It's ADA height, which Dave needed, and it really makes a difference.  And it goes without saying that if men are going to be using it, you want an elongated bowl.
I shopped around quite a bit but I came back to the Clean Cadet 3 because of its smooth sided design and clean lines.  I'd love to have a wall-mounted toilet but that's only going to happen with a complete gutting and remodel job, so the clean sided design is the next best thing.
One thing to consider is that you'll be better off if you have help when mounting this particular model onto the flange.  Since you're not able to see the holes for the bolts to fit through as you lower the toilet onto the flange, you need a spotter.  There are two large holes on each side of the skirt which provide access for tightening the toilet down, and as well as a side view when positioning the bowl portion onto the flange.
I'm generally pleased with the way this toilet performs even though it's a low flow model, and surface area of the water in the bowl is larger than most.  The cost was around $230 at Lowe's (the only place I found that carried this model) and I think they've come down in price since.
My main complaint is that the "Ever Clean" surface isn't, and because of this treatment you can't use strong abrasive cleansers to clean the bowl, and certainly not a pumice stone, which I use once in a while on the other two toilets here because they develop lime deposits.  The "Ever Clean" doesn't seem to allow lime deposits to form, but there is a faint ring that "scrubbing bubbles" types of cleaners along with a bowl brush can't quite get rid of.
I've attached a picture and linked to a demonstration video.  Notice in the video that in almost all cases, it appears the flush lever is being held down until the bowl clears.  My experience has been that for routine jobs, it's usually not necessary to hold the lever in order to clear the bowl.
Went shopping today
After researching and shopping around today, I decided that the Cadet 3 is the best choice and most widely available. A big plus is the flush mechanism isn't as complicated as some of the other brands. And flush and recovery is powerful and quiet compared to others.
Malcolm
I have the Cadet 3 toilet and its a life saver since my knees are not next to my ears!
The flush is strong and powerful just remember to hold the handle slightly longer than your regular bowls!
Cleaning is easy and can be done every other week if you aim right!
Larry, what do you use to clean your Cadet 3?  I think I need to use something stronger, but want to stop short of cleanser.  I don't care much about voiding the warranty on the EverClean surface (because it most certainly is not) as long as the appearance of the bowl doesn't get weird from using a product like KaBoom on it.  The foaming cleaners I've been using just aren't cutting it.
The best toilets by far is from Caroma there a Aussie company and they are a gravity type but made totally different than
U.S. types.The all have a 4 in trap and the flush is a dual flush but the best thing is they never clog.We have a ton of rentals
well my Family does and that is one thing we don't skimp on is toilets.We used Toto for the longest time and they are good
but there $$$ compared to the Caroma and they can't hold a candle to the Caroma brand.They are a low flow but they remind
me of the old ones where you flush it one time not 10 or 12 and the whole bowl is cleaned.Check out this Video on You Tube of
it they put a whole roll of paper in it and no problem not even close.They run about 350 bucks which is not bad I think..
http://https//www.youtube.com/watch?v=ryIQYYogQ8A
Washout Toilet . . .
A German friend of mine told me that the usual argument he always heard for this type of toilet is that because the "deposit" drops onto the shelf and not initially into the water it is impossible to get water splashed onto oneself. I will agree that having water from a public toilet splashing onto oneself is off-putting, but what I find even more obnoxious is the instant smell that comes from these toilets. The latter is of course the reason for not having one.<a name="preview"> </a>
<a name="preview">
</a>
<a name="preview">
<p>I would however prefer to have a washout toilet than the little rectangular hole-in-the-floor fixture used in some places!
</a></p>
I am not sure of what my niece had just installed in her house, but they ran about 500.00 a piece, super freaking quiet.....it came down to the bottom line, you get what you pay for......
but no matter what toilet I have or had installed, I always change out the flush mechanism to one that allows me to stop the flush in the event of a backup/flood, before it happens, just by raising the handle....my kids drop eveything in there except what is supposed to go down there.....
worth every single penny versus a mess on the floor.....
http://www.lowes.com/pd_247823-143-...currentURL=?Ntt=toilet+flush+valve&facetInfo=
