history of whirlpool leap design 2000
gelaundry4ever
Nov 18, 2014
4,679
Temple, Texas, USA
Hello everybody. I've been trying to find more information on the design 2000 leap platform washer. Unfortunately, I couldn't find any more info on these.
What was the purpose of this machine design? What was the agitation stroke and rate they came up with and why? What other changes were made to the transmission, pump, and motor? Did they use the same or similar lubricant in their transmissions? Did they use a different lubricant to enhance the performance of the transmission? How many parts are in the gearbox? This was a revolutionary, high-tech design for it's time if I'm not mistaken. This has to go down as one of the best designs out there.
Fortunately, there are still plenty around, some of which are in my dorm at SFA under the maytag label. What are your thoughts from whirlpool fans?
I think part of the reason for the faster agitation stroke was that the tubs were narrower and deeper. Especially the first 24" designs like my machine is.
I have an Estate DD from 2003-4 ? Model # is TAWB600JQ0
Serial # 110.CP1728951.
Just replaced the water valve 2 days ago on it. Had to drive over an hour to get the part but was well worth it and $37 later I saved a bundle from having a "tech" come in.
agitation arc confusion
Some say that the agitation arc on the design 2000s are 90 degrees, while others say it's 100 degrees. Can somebody clear that up once and for all? I believe the Maytag Centennial units were also based on this very design before the changeover.
My copy of Whirlpool's L-46 "Design 2000 Direct Drive Washer) service manual copyright 1981 states --
Agitate Speed:
  177-181 Strokes Per Minute High Speed (commonly referenced as 180 SPM)
  118-122 Strokes Per Minute Low Speed (commonly referenced as 120 SPM)
  100° Arc
  (3-speed models later added an Extra Low speed of 88-92 strokes per minute) (commonly referenced as 90 SPM)
Spin Speed:
  640-650 RPM High Speed (commonly referenced as 640 RPM)
  425-429 RPM Low Speed (commonly referenced as 425 RPM)
There are too many differences on direct-drive vs. classic belt-drive to detail all of it.
Direct-drive transmissions are all the same gearing for the duration of production.  KA machines had the same 1, 2, or 3-speed motors as all the other brands so produced the same SPM at the same motor speeds.  They're different only in that models with the larger-base agitator ran low motor speed for high agitation (120 SPM) and ex low motor speed for low agitation (90 SPM).  Early models without the larger-base agitator ...circa 1987 and maybe 1988 ... didn't do that so those were 180 and 120 SPM.
The Reason DD Washers Had a Faster Shorter Stroke
Was because it cost less to build because they could use the same reduction gears for spin and agitate.
FD did this with the Pulseamatic machines in the mid 50s that spun at 660 RPMs and agitated at 660 strokes per minute, Philco also dis the same thing on their Auto-Magic washers and of course MT did this on their orbital helical drive washers.
John L.
John L.
d2000
Thanks Dadoes. I appreciate you for clearing things up. I guess that's how Maytag was able to claim the 100 degrees arc. Didn't Whirlpool decide on the 100 degree arc with 180 spm for better soil, dirt, and stain removal? The higher 640 rpm spin sounds obvious for better water removal. That full speed agitation can surely stir things up whipping up a whirlpool.
When I had the Amana with the long stroke agitation it was good on anything less than really full loads. With pauses between each stroke it loses the momentum to pull down bulkier stiffer fabric.
That machine has the same tub as the SC DD washers with a claimed 3.5 cu ft capacity. So I guess the DD washers didn't really need the fast stroke for a narrower taller tub. Those machines NEED the DAA for better rollover no doubt.
I have a new appreciation for the smaller DD 24" washers like my current Estate. No BS, just straight forward cleaning with a true spray rinse.
I have an appreciation
for the dd myself, especially after taking place of the durability of the GE filter-flos which I miss. My babysitter and VI teacher both had a whirlpool one of being the clean touch model which you could hear the humming of the motor clearly during agitation. They also had the matching dryer.
Post FL washers
These had very short and fast strokes. Tiny transmission. The only good roll over was on low. On high water, the clothes would sit still while the agi and tubs would jiggle around them. Thee worst washer that could ever have existed.
Excuse me, but I cannot see
the video being shown in terms of the transmission size comparing the whirlpool and GE transmissions. Please describe. From what I understand, the whirlpool agitates at 100 degrees at 180 strokes per minute. Is this correct? What about compared to the GE?
transmissions
I believe the dd transmissions weigh 17 lbs while the bd ones weigh 25 lbs and have pulleys. I'm intrigued about how Whirlpool was able to use large transmissions.
What did they do to make them lighter? Did they make them smaller, narrower or shallower?
been a while...
Sorry it's been awhile, but I have been busy with school. I did purchase some whirlpool gear oil and it smelled like 90 weight oil. Did it make this washer transmission louder then some other whirlpool models? Did they fill the gearbox completely? What is the viscosity exactly? It does seem very thick like maytag and GE gear oil. I suspect they use this oil in their maytag units built by whirlpool later on.
