HI Everyone,
I got a Hobart FFW off of Ebay last winter. With the help of the forums here I got it cleaned up and installed. It works great! That is until a couple of weeks ago.
The unit was sitting on but not cycling when it popped the breaker. When I took the front panel off I saw the incoming power connection had melted. I have 6 gauge range wire (silver in color) to a 50 amp breaker. That goes to the plastic distribution box where it was connected via screws to the units incoming power lines. I assumed it was due to age and perhaps some corrosion. I installed outdoor wire nuts rated for 220 that have di electric grease in them. After only a week of residential use that too melted and popped the breaker. I have noticed this has happened when the unit is sitting in idle and is steaming from the water heaters.
I am going to buy the correct connector from Hobart to replace it this time.
My question is how can I tell if there is something else wrong? Is the heater not turning off creating excessive steam or pulling extra power?? It seems to sit and steam and bubble the water around when its sitting there? Any other thoughts?
