I have a hobart ffw setup in my home. It was installed about six months ago and has worked great. Recently it has started popping the breaker typically while sitting idling. Troubleshooting led me to unhook the main tank heater and voila it stays on! I took the element out and it is filled with lime. I am going to try and track down an element tomorrow. Two questions
Can you use a standard element purchased at a hardware store
What is the best way to clean out the tank both now and for future maintenance, I have delime solution and run the regular delime function but I am assuming that doesn't get water to the tank?
Thanks in advance!
Thanks in advance!
