Hello everyone!
So I spotted a Hoover twin tub washer the other day and took the chance to buy it as I always wanted to try one.
It's a 0611 which is apparently your basic unit. It was relatively clean and there wasn't too much rust. WD40 and two test cycles found no electrical or mechanical problems however....
1)The pump leaked
2)The spin tub buffer seal was leaking
Top priority was the pump. Instead of leaking at the O-rings it was leaking out the valve seal at the top at a fairly fast and steady rate. A replacement seal could not be sourced so I rectified it by installing in a tightly fitting o-ring inside and stuffing the cavity with grease.
http://i11.photobucket.com/albums/a166/ballsandy/CGS_0190.jpg
http://i11.photobucket.com/albums/a166/ballsandy/CGS_0191.jpg
http://i11.photobucket.com/albums/a166/ballsandy/CGS_0192.jpg
The whole pump was dismantled, cleaned and the o-rings regreased even though they were fine.
The buffer seal is different. From the looks of the spray pattern it's been doing it for a while however it's a mere drip compared to the torrent of water from the pump. I removed the spin can and pulley and the inside of the buffer is starting to crack so I want to remove it, clean it, and apply silicone goop as well as take a drill brush to the inside of the tub to clean up the corrosion blisters.
I removed the snap ring and according to the exploded view you push the seal into the tub ( http://cdn.appliancepartspros.com/images/diagrams/dcache/0028310441_4.gif
...however even with a wooden block and a hammer I can't move it. Does it normally take a large amount of force to remove old buffer seals or has it rusted and reacted with the aluminum tub?
1)The pump leaked
