Hoover 1100F sump hose replacement
What is an 1100F?
If it is Australian made, I'd have one. (good used.)
If it is what I think it is, it's a Beko with Hoover badges. I wouldn't have that part, but they were also sold as a Fisher and Paykel in moderately large numbers so parts should be around.
Post a photo of the ID plate and of the hose. I can compare a photo and see if I have a match.
Unscrew two clamps (one each end), remove old hose, transfer clamps to new hose, refit.
Couldn't be easier.
Clamps are probably screw clamps, but might be springy wire clamps - in which case, squeeze the wire ends together with a pair of pliers (multi-grips are good) which expands the wire clamp enough to slide it down the hose, allowing you to remove the hose.
Can you please post a photo of the damaged hose, in position, on your machine.
If I have a matching hose, and I almost certainly do, you can have it free, just pay the postage.
Ohhh cool I’ll send a photo
But if you’re wondering why there is duct tape holding the pump in place, it’s cause when this machine was moved I don’t know how but the little pump clips that hold the pump in place broke
