Hoover 3203 Keymatic Video
Garys Teatowels
Well they are a hell of a lot cleaner than that ACDO u were using on them in your Matchbox Keymatic.
I had to start on the stains somehow.
Im no slut............
OMG....
i have just pi$$ed my pants with laughter!
You really do have the knack for the funny caption competition. Brilliant. Just brilliant.
Paul
keymatic with impeller. Need somme help again!
hello,
I progress in repairing the keymatic...
Thank you for the information on water levels and documentation. So I repaired the hoses, but in trying to operate, there is a leak at the impeller with water splashing when it turns. My questions are:
Can we still find a gasket and where?
Otherwise, how to disassemble (from inside the drum or rear?)
Have you a diagram with the parts?
In advance thank you for your help and sorry if my English is not great.
anyway I promise you that when the machine will completed I will make pictures.
Bert
Hi again and thank you very much for your reply.
Yes, the leak is coming through the back of the drum and there is no particular like. But there is a leak when the water reaches the bottom of the impeller, even when it does not rotate.
In fact, I dare not remove impeller because I am not sure of being able to assemble properly afterwards. Moreover, disassembly seems very complicated, and if the seal is wrong, how to repair because it is certain that this seal can not be bought anywhere! What do you think?
Otherwise, I tested the program spin: the timer and spin are ok. The valve also works but I do not know if the machine automatically stops the water because I have also put a seal between the door and opening
see you
Bert
