Ive just got a hoover keymatic the oldes modell 3224,
Ive got it for free, and a can post a pic later , but the biggest issue is the door seal boot...
Wounder if someone can tell if i Google the door seal gasket, that the dbt28 seems to fit? Or some other suggestions? I have not powerd it up jet, hehe 2phase 400v erth, no neutral the manual says in swedish, its a 3wire cabel 2,5mm2 , 3000watt heating, so i guess its made for just 2phase and the neutral is together with eart in the machine?  abit nervus about that, would not like to toast the washer.
, but the biggest issue is the door seal boot...Wounder if someone can tell if i Google the door seal gasket, that the dbt28 seems to fit? Or some other suggestions? I have not powerd it up jet,
 all other rubber houses seems to be fine, and the clutch brake sems to not look to bad...
