bigwashingdayau
Well this afternoon I picked up my $20 twin tub.. Was in a very sad state, but the lady insisted she it worked.. Got it home in my 2dr Hatch (what a mission)..
I plugged it in and both motors fired up beautifully!
The Pump I think hasn't been used in a while it didn't want to pump but I only poured 2L into the spin tub hopefully that might loosen it up overnight?
I spent 2 hours with Spray n Wipe & JIF scrubbing it up. Came up quite good for now.
I attached some initial photos as I'm going to inject some good ol' TLC & Elbow Grease into this machine. My goal is to bring it back to the life it deserves, and hopefully get a couple of years out of it.
I put a Project Goal below, and updates.. This will be my first Vintage appliance restoration.. I don't know how to feel. I think Excited/Anxious But cracked a Vodka for now and just trying to make a plan and to enjoy the rest of my evening. Have a good one all.
Cheers!
Adam.
Project List: (tried to put it in project order too).
1) Try to get current pump to work although i didn't do much testing this evening.
2) Remove the spin Wheel on the base of the machine chassis and sandpaper the rust off and apply some grease or oil.
3) Try remove all rust and patch up rust hole on front (pic attached to post)
4) Remove Pulsator for a good clean / grease.
5) Inspect all seals and replace faulty where applicable.
6) Replace all Belts.
7) Replace Wheels.
8) Test Run.
Cheers!
Adam.
7) Replace Wheels.
8) Test Run.
