wishywashy
Active member
Hello again Gents! I'm in the process of sorting-out a couple of Hoover Twin-Tubs (one T1060 and one T1302), and I'm at the stage of removing the various belts to inspect them.
The Agitator Belt is a simple enough exercise to remove and replace, but the Spin and Pump Belts, however, are a different kettle of fish. I started writing out a longer version of this question that explained the subtle little problems involved with replacing the Spin Belt in particular, but thought it might be much simpler to instead just first ask whether anyone knew of the Factory-approved method for replacing either of the Belts - Spin or Pump? (but mainly the Spin...)
In order to save some of you TwinTub devotees the whole rigmarole of generously going out to the Shed and turning one of your little "babies" upside down (with the attendant ensconced water spilling out all over the floor into the bargain...) to have a re-familiarising look at the machine's general internal layout, may I please proffer the following photo instead, which is of the underside of a T1302 (with Belts removed), depicting:
- In the upper left corner of the photo, the Spin Tub Pulley
- In the upper right corner of the photo, the Spin / Pump Motor
- In the lower right corner of the photo, the Pump Pulley
So once again, the question is - Does anyone know what the Factory-recommended method is for replacing either the Spin Belt or the Pump Belt? (a scan out of the Service/Repair Manual would be great!!!)
Many Thanks in advance,
WishyWashy.
WishyWashy.
